Results 1 to 4 of 4
    Default Citroen C6 2.7HDI - P1350, P1351, P1352 - CHECK and limp mode
    Hi,I have a problem with errors P1350, P1351, P1352. Glow plugs relay is new. Glow plugs are ok (11-12A). Preheating relay is ok. Errors after erasing return and after a minute of engine operation appears light CHECK and limp mode. Wiring relay to ECU (sid201) checked. +12V, 68 (IGN) and GND of relay are ok. Lexia can activate the relay glow plugs.
    I do not know the history of the car. It may be the fault of software or faulty ECU? Can someone have similar case?
    Thanks! BR
    Oct 2012
    THERE ARE SOMMES ERRORS THAT CAN NOT BE CANCELLED WITHOUT DISCONNECTION OF BATTERIE....SO AFTER USING DIAGBOX-LEXIA,DISCONNECT BATTERIE FOR 10 MINUTES,AND TEST AFER THAT....ATTENTION...LET OPPENED THE WINDOWS OF THE CAR FOR NOT CRASKING GLASS...BSI IS A FUC..NB BODY COMPUTER WHERE CAN REST MEMORISED ERRORS AND AFTER USING DIAGNOSY
    Sensore B livello carburante P1350 intermittente / Line Bypass Monitor
    P1351 Circuit IDM Malfunzionamento di ingresso / Controllo circuito di accensione bobina di alta tensione
    Ignition Coil P1352 un problema di funzionamento circuito primario
    Oct 2012
    so it is a ellectrically probblem,maybe low tension on batterie, fuel levvel problems,maybe the sensor inside the fuel pump,into the tank or wires with probblems,and probblems with the high voltage bobine
    Thanks mate for answer but Lexia shown that all this DTC is from glow-plug heating system, not fuel etc
