Is is possible to edit the ecu file to remove the speed limiter on Vauxhall/Opel diesel engine ECU?
I have customers with Combo and Astra vans but I don't use Tech2, just original VauxCom and AVDI with no speed limiter options.
Cheers
Cheers
What years are they ex German gas cabs or post irrfice ir something
Ex-Southern Gas or BT usually,
Vauxhall Combo 1.3 CDTi Marelli seem to be the most common.
Cheers
Just have a tweet and squint at the gas pedal. Sometimes there's a plug in box to the gas oedal
Thanks MH,
No Siemens box add on's, they are definitely restricted in the engine flash.
Usually 50/50 hardware or software with most vans we see depending on who did the limiter.
SPASTIC MODE:-
cant you leech a flash off here to try, check year first?
Atex31 (30th June, 2014)
You're probably right,
Plan B it is:
Start collecting flash files from un-restricted vans and write down the part numbers.
Surprised it isn't an option with AVDI though.
Or doubt it, ebay leech a few ecu s
rumor states there's immo off for them, but
1) lost the tgread
2) the ****er passwirded ut
Cheers MH,
We do loads of vans so no bi-gee to collect flash files.
Thanks for the inspiration![]()
I did a astra van the other day with the stupid box joined into the pedal. It was also joined to the back of the light switch. Just behind the light switch there was a fuse. Just removing that fuse is enough to disable it.
It confused me for a few minutes as there was not the normal dpf + speedlimiter options in my tech2 when I went to reflash it.
AVDI runs tech2win + SPS so you can reflash if you need to.
Or swap ecus over on the one fir the brakes, when he comes back next week, limited speed, tell him ecu screwed ?200 to fix, swap with one off ebay/ his orginal flash abs awY. (iShit Failiure) hate it
