Results 1 to 15 of 30
    racin-snake's Avatar
    Jun 2009
    Default vag commander k + can help
    hi everyone ..newbie so be gentle
    i have bought the above tool from china for one specific detail crash data clearance . but it will not install properly i have had a few attempts ..i also have vcds .. but it cannot erasecrash data ..can anyone talk me through a succesfull install ?
    the version is 1.4 .. i am also looking for a programme and firmware update for op-com .. any help appreciated ..i have other car diagnostic software to trade ...shuggy
    Jun 2009
    can anyone help with the install on this one ? any tips on how to get the drivers to instll ? there are no exe files for startup .cheers
    Jun 2009
    Default Vag K Can 2.5
    Please help in installing a dongle Vag K Can Commander 2.5
    http://rapidshare.com/files/251409354/Dongle.rar
    Jun 2009
    Default Can you send to me by mail
    Quote Originally Posted by samiko View Post
    RapidShare: Easy Filehosting
    I can not download this
    racin-snake and samiko, can you both post pictures of your interface ?
    Perhaps we have the same interface.... I've posted
    a few pictures of mine in this thread :
    http://www.digital-kaos.co.uk/forums...-v1-4-a-44133/
    2nd and 3rd page.
    Thanks.
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Hi Does this install the files to a dongel or make the program not need dongel ?
    Jun 2009
    Quote Originally Posted by Chadder View Post
    My interface 1.4 I was trying program 2.5 +Dongle well unsuccessfully.Dongle oneself me unsuccessful installed.
    Please help.
    Please stick for the moment to the V1.4China version, that came with the cable, or is referred in the other thread abouth this interface. Just for the record, i'd advise you to re-read that thread completely, as i and others advised people with trouble, getting this cable to work. A quick downloadlink for you that will help you with getting the stuff to work :
    This works with the black cable withouth the extra supplied usb-key-stick (Dongle). I can't confirm this if it also works with that version of the cable, as i don't own that combo or heard success-stories that it indeed was functional with it.
    First of all, try a freshly installed pc, with windows XP or lower operating system. XP works 75% of the time perfect.
    And remember, to NOT put the OBD-side of the cable already into the car's OBD-port, while starting up the software. This mostly will give the problem as the software will not open up.
    And DO NOT install that DOGdriver for starters. It will only create problems if you DON'T got a usb-key-stick (dongle) with the cable and the software supplied.
    Hope this helps getting you up and running.
    Regards,
    P@z
    GB
    hy to evry body have u .ept filles for my ftdi cause did not recognise mi interface
    matekhr's Avatar
    Croatia
    That's what I have....
    Jun 2009
    Have you a good dump (.hex) for PIC18F258 also ?
    matekhr's Avatar
    Croatia
    It's here, but I didn't test it myself.
    It would be good if someone can confirm this dump is OK...
  13. #13
    @ matekhr : Would you be so kind to tell me, which program you've used in the file pic18f258 fuses.bmp ? And did you physically desoldered the pic-chip ? Thanks
  14. #14
    Jun 2009
    Desoldering not need,but it has protection in configuration - locked.
  15. #15
    matekhr's Avatar
    Croatia
    Quote Originally Posted by pvl View Post
    Like "vares" said, desoldering is not needed, but pic's are usually locked, thats why you need to know the configuration bits. Also, there are many pic programmers on the market, every one has its own software, configuration screens provided with dump are for reference only. I don't know which program is used in *.bmp file.
    And, I didn't need to re-program my k+can interface, so I didn't test the attached dump myself. (but I had to "revive" my other interfaces, like vagtacho and vag-com...)
