I've this Corsa D yr 2008 1.3 CDTI Y13 DTJ, that refuses to start...! When turning the key from 0 to "panel lights" and then to start position, the motor doesn't crank at all... When turning it directelly from 0 to start position, the motor cranks but doesn't start.
I've already reseted, programmed everything I can imagine, but nothing. Both with OpCom and Tech2.
Also flashed engine ECU with Tis (it upgraded the software).
As I think, I've here a BCM problem (the car was stopped (crashed) and without battery) I've tried to flash the BCM with Tis, but it says "unknonw software" or something like that and won't go ahead...
Because the old (original) one was cracked, I've already changed the cluster (maked it virgin and reprogrammed it with car's original pin), It says 51k km, while OpCom reads 180k km, but I don't think this this would be a problem, right? Perhaps, however, related with the radio display showing "F" on top right corner.
Of course, as you can imagine, I' ve already spent "thousands" of hours googling everywhere and with the car itself. However, I'm really stucked with this one...! And also, it has a few DTCs, related with EHU and BCM, as for instance Mid Can configuration not complete, etc... in spite of having done Mid Can config dozens of times.
Can someone point me a solution/idea on this one?
Should I disassemble BCM and try to reflash it? Perhaps corrupt software? Does someone has virgin file for it and can send it to me?
Please HELP, HELP...!!
Thank you SO MUCH, in advance.
BR,
PM.
