Results 1 to 12 of 12
Thread: Astra H immo Off
    34
    Default Astra H immo Off
    Hello, I was searching the forum and did not find anything I can fix. I did not see any program that can help me. I have an ecu for Opel Astra H CDTI 1.7 DTL diesel
    Bosch 0281011943.
    You can immo off? Inside there are 2 eproms (89847/0430) and flash (29BL802CB)
    Thank you
    a greeting
    You can't do immo off on astra h. You can adapt very easy ecu to car
  3. The Following User Says Thank You to cool2503 For This Useful Post:
    diyre (15th July, 2014)
    34
    thanks for your reply. The vehicle does nothing the starter and flashing light, giving breakdown of immo.
    I will continue looking for another solution.
    a greeting
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    286
    if the ecu and cim is ok read pin of car and program new key
    First scan car of dtc especialy ecu,cim,ipc,uec,rec see what codes dosen't delete and post here to help you to resolve problem.if astra h have problem with immo system don't crank just put ignition on.the main problem of astra h is cim defective
    34
    thanks for your answers,'ll check the codes.
    I think the problem is as PSA, the Control key opens and closes doors, but does not send code to boot.
    a greeting
    Wrong.remote control just lock/unlock dors .to start engine is a cip inside of key that is read by cim and authorize start engine
    super jumbe's Avatar
    Livingstone
    4,963
    If I were you I would rule out CIM module, after reading most forum customer was advised to get a new virgin CIM module from Vauxhall dealer costing over ?500 we still have the same issue, no ignition on dash, car will communicate with every module accept ECU I think ECU could be faulty.
  10. #9
    Sep 2011
    In the Garage
    286
    the first step is read DTCs of all modules, then maybe we can help you
  11. #10
    34
    Thanks for your answers, the P1614 and P1616 are failures. The key chip is included in the same remote control so I think I can open and close but not to sign for the immo. It is a typical PSA failure.
    a greeting
  12. #11
    Sep 2011
    In the Garage
    286
    Check coil of key, for sure is broken
  13. #12
    west mids, uk
    467
    astra H is not PSA system, read fault codes from cim and ecu and airbag and cluster, also check that the VIN is correct in all modules.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
