Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    Default Chevrolet Spark 8E programming
    Which programmer do i use for 2010 Spark with 8E chip
    Try what you got
    iPhone Tapatalk
    Obviously i already did, or i wouldn't have posted
    dyzio's Avatar
    Jan 2014
    Racek
    u need key from dealer
    I connected with avdi Opel and gscan
    iPhone Tapatalk
    On this car the 8E chip just stopped working and when i read the key i get "No transponder"
    I have new 8E chips in my stock, and on avdi lists only cruze and captiva, Does Gscan do key programming for Spark ?
    i connected under opel - i think it got cim model
    Ferizaj KOSOVA
    I think that with ZED-FULL you can programm this transponder but its not cheap solution
    Gagica LOCKSMITH
    Kosova
    westville locksmiths's Avatar
    Sep 2011
    South Africa.
    Mvp work ,
    Has anyone got solution to this or knows what the problem is with producing the 8e chip.
    Surely the dealers havent got the stranglehold on this chip.
    Anyone know which chip needs to be read in this box 116RI-000072 IM860 Immobox pink label
    leandroks's Avatar
    Brazil
    Fvdi gm is a tested solution;..
  12. The Following 2 Users Say Thank You to leandroks For This Useful Post:
    doctore (2nd March, 2017), kevfield (18th August, 2014)
  13. #12
    kevfield's Avatar
    uk
    Hi leandroks i have FVDI can you help me with the process to do this ? i can't seem to find any info in my software for this late freescale chip .....
    Thanks kev
  14. #13
    leandroks's Avatar
    Brazil
    Sure, whe n u tray to connect with immo what message have u got????
  15. #14
    Aug 2010
    Australia
    I have done a couple of these 8E chip for Spark, it is precoded 8E and dealer key only. I used Gscan to program the key and it worked well. I tried normal 8E chip and it would not work.
  16. The Following User Says Thank You to jamesnz888 For This Useful Post:
    lalaina74 (20th October, 2020)
  17. #15
    kevfield's Avatar
    uk
    Ok programming key is the easy bit but precoding you are saying cant be done ??? so what your saying is that the only way to do this key is to buy precoded key from dealer and program
    Thanks kev
