Page 18 of 21 FirstFirst ... 8131415161718192021 LastLast
Results 256 to 270 of 312
  1. #256
    Mar 2013
    Anyone know how to repair ABS module in Audi A6 C6 - 4F0 910 517 L ?
    I have 01418 DTC - Switch valve 1 for electronic stability program N225
  2. #257
    Oct 2015
    Hello;
    I've MK61 from Fiat Doblo 2011 ; after reset adaptation I can not relearn valves. ABS/ESP and Hill Holder blinking on the dash. I try use many diag tools for try fix it: AlfaOBD, MultiEcuscan, Delphi... but no results. Error message is: Procedure timeout. What can be wrong?
    Number of pump:
    51901330
    DTC:
    C1203
    C1206
    many thanks for help solve this problem....
  3. #258
    Top Poster Pepesoft's Avatar
    Jan 2017
    Finland
    Hello
    Have mitsubishi lancer 2008 with abs fault C2116 pump motor voltage low active.
    Fault came when battery died.
    Ate controller, pics attached.
    Any idea where to start?
    Petrol is for cleaning tools, with Diesel we make power!
  4. #259
    May 2018
    I need help with ABS ATE MK61 (1K0 907 379 AD) module with no communication from audi.
    I reflow BGA chip, resolder MCU and solder pins from chasis to PCB but I haven't tested yet.
    Is it enough to fix the fault?
  5. #260
    right here right now
    Quote Originally Posted by Fuller View Post
    Was this repair successful as i have the same problem,
    Sent from my SM-G950F using Tapatalk
  6. #261
    May 2019
    Audi A4 Quattro Model 2000 comes up with error message of faulty "Brake Pressure Sensor".
    I know that this is Bosch ABS 5.3, cause it have ESP it additionally have a hydraulic pump sitting under the ABS.
    And the Brake Pressure Sensor sits on this hydraulik pump:
    According to AUDI / VW this sensor is not changeable, the whole pump needs to be replaced (~ 700 EUR).
    Does somebody know why that is? Or maybe there's a way to replace it anyway? What spare part could be fit?
    Thanks for any information,
    srx308
  7. #262
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by soxten View Post
    Is it bmw bosch "...001"?
    This have always bad connections/broken alu.wire.
    I did 2 last week.
    Christian Johansson via Iphone 5s
    How can i solder these wires?
  8. #263
    Mar 2020
    Quote Originally Posted by Sudnut View Post
    Hi All,
    My repair has worked. IC 9369.1D was replaced and 5df5 internal fault has disappeared. Very happy😁
    yessssss
    i have the same error in the same module.. i order one IC 9375.1B from the aliexpres.
    (original ic from my module is 9369.1D) .
    i am replaced and the unit work again!!
  9. #264
    commieTH's Avatar
    Jun 2016
    Thailand
    don't really know where else to post this... I have a problem with 2009 Toyota Alphard steering wheel position sensor 89245-33040 (part of ABS system too), it doesn't show right data and live reading doesn't change with wheel rotation. I read a dump from 24C02 inside but I am not experienced with those so no idea if it's good or bad and/or how to fix it. Can anyone help?
  10. #265
    Sep 2018
    I fixed a lot of abs. especially Asian cars. which is actually more difficult because the components are smaller. but the outline is the same. like fixing ecu. 1 voltage source. 2 processors. 3 actuators. here the actuator is often broken. mosfet. replace stronger or closer.
  11. #266
    Sep 2018
    why do you have to read eprom 24cxx ..? eprom contains sincron data module 1 to another module. which must have been synchronous. reading from right and wrong depends on the sensor used. often the sensor has an error. hall effect or optic ... if it helps thanks
  12. #267
    Sep 2018
    the electric motor mosfet is dead. replace something similar or close.
  13. #268
    Sep 2018
    Quote Originally Posted by commieTH View Post
  14. #269
    Aug 2014
    Did you fix your qashqai abs, i also have same one running all the time?
  15. #270
    Sep 2019
    Hello, I have a problem with my Subaru Outback MY2010 ABS/ESP-unit. Only today, I found this thread, but I started an own thread here:
    https://www.digital-kaos.co.uk/forums/showthread.php/839324-problem-with-EUDM-Subaru-MY-2010-ABS-ESP-how-to-reprogram-the-unit?p=3919986#post3919986
    Please would you be so kind to take a look there? Thanks, Guy
