Page 8 of 21 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 312
  1. #106
    I'm trying to power up the ECU with this:
    Earth pins 16 and 47
    +12v direct 1, 3, 17, 32
    Ignition +12v 29 and 38
    Is it right?
  2. #107
    Sep 2015
    Hi, Where is the VIN stored inside the ATE ABS module on a BMW E46 part number 6759075? Would it be stored inside the ST circuit 95042U3? or inside the big ICs/MCU?
    I wanted to buy a used module, but will get stuck with the VIN difference. Is there a way to clone it or to transfeer the chip containing the VIN data from the damaged unit into a working unit, and which chip stored this VIN data?
    Regards.
  3. #108
    Quote Originally Posted by James MR2 View Post
    Regards.
    WINKFP (Inpa tools) can made it for you.
    Tool32 also can.
    Simply mount in car and recode with new Vin.
  4. The Following User Says Thank You to GolfmkI For This Useful Post:
    MV auto (13th April, 2016)
  5. #109
    Ive tried to repair Abs Mk60 Golf V 2009
    Resoldered whole Pcb
    Error 01130 wont dissappear at all.
    Also 01276 is showing sometimes.
    Pump is ok(tested).
    Fuses and Feed are ok (tested)
    Any idea??
  6. #110
    Lithuania
    Fault description?
  7. #111
    Jun 2011
    Northamptonshire, UK
    Hi...
    Does anyone have a power-up / pinout for a 2008 peugeot 207 Teves MK60 ABS Module..
    I have one that has no comms but module has been away and check and come back fine...
    Cheers
    Nik
  8. #112
    Jun 2011
    Solved...
    here is diagram if anyone happens to need it in the future..
  9. The Following 4 Users Say Thank You to Music73 For This Useful Post:
    brchip (1st May, 2016), Donabe (30th June, 2020), lush29 (1st May, 2016), mexanico1971 (3rd August, 2016)
  10. #113
    Mar 2011
    I have the same problem with one bmw E90 abs with brake pressure sensor problem. Any solutions? I have open the top cover of the ABS ECU but inside all look like good. I check with multimeter the pressure sensor that is in the alu block and have demension. did anyone resove this problem?
  11. #114
    clusters's Avatar
    Mar 2015
    Canada
    Only ever solved this by replacing ABS unit on the ones I have had problems with.
  12. The Following User Says Thank You to clusters For This Useful Post:
    Stelaras (24th November, 2017)
  13. #115
    LT & ES
    Had one Volvo v70 from 2004 , strange things on the dash board, no speed, no cruise control, "abs fault stop engine", internal module fault. Under microscope moving Ate chips legs, found 3 dry joints. Just resoldered all chips legs and no more faults.
  14. The Following 3 Users Say Thank You to olegario For This Useful Post:
    gomarota (24th January, 2017), soxten (1st June, 2016), violator11 (1st June, 2016)
  15. #116
    lush29's Avatar
    Oct 2015
    Hi all. Have an auti tt fault code 01276. Abs pump no is 8j0614517.did same one come across this? Thanks
    Sent from my SM-G925F using Tapatalk
  16. #117
    please help to C1380 abs pump blocked how to repair fault thans
  17. #118
    lush29's Avatar
    Oct 2015
    Hello. Have an corsa D 2007 abs po no 0265 800 422. And 1 caliber is not locking the well because one valve in the block is stuck. Is anyone came across this with an solution? Thanks
  18. #119
    Jun 2011
    Bba reman refurb these pumps on a regular basis as this is a common issue.. Left front brake stops working.. Unfortunately I don't know what the repair is...
  19. The Following User Says Thank You to Music73 For This Useful Post:
    lush29 (30th July, 2016)
  20. #120
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by Music73 View Post
    I had with right brake also. I know bba they do them, but i want to see if someone else is got this sorted. The valves on the aluminium block is getting rusty and is stops working, thats how far i know. Thanks
  21. The Following 2 Users Say Thank You to lush29 For This Useful Post:
    mexanico1971 (3rd August, 2016), Stelaras (24th November, 2017)
