Page 1 of 21 12345611 ... LastLast
Results 1 to 15 of 308
    soxten's Avatar
    Mar 2013
    Default How to repair ABS system and units thread (repair,help,questions)
    Under this thread we talk about how to repair ABS system and units.
    ABS unit is often get broken and sometimes it is easy to repair.
    If we all share info about how to repair this units, all members on DK can get help.
    Please put our info and questions in this thread and if the thread is becomes big we my have a new master thread under Garage as "ABS system"
  2. The Following 8 Users Say Thank You to soxten For This Useful Post:
    borshch (1st January, 2018), DAVID8HENRY8 (8th May, 2016), engvitinho (20th May, 2023), lobofelix (3rd April, 2023), mexanico1971 (21st October, 2016), PierreTheron (11th March, 2016), shadab (25th November, 2014), Stelaras (24th November, 2017)
  3. #2
    soxten's Avatar
    Mar 2013
    Her is a thread of how to repair ABS unit to a Rover.
    Fault is that ABS pump engine is constant runing.
    The mosfet transistor was broken, see pictures in thread.
    http://www.digital-kaos.co.uk/forums...r-75-a-422432/
  4. The Following 6 Users Say Thank You to soxten For This Useful Post:
    carteknik (8th July, 2020), gameiruz (5th October, 2016), jmac200t (25th November, 2018), mexanico1971 (5th November, 2014), MV auto (11th March, 2016), PierreTheron (11th March, 2016)
  5. #3
    soxten's Avatar
    Mar 2013
    Here is how to Repair Vw ABS units when you don`t get any comunications (it`s totaly dead)
    http://www.lbak.dk/Audi/Repair_ABS_unit_passat.pdf
    When you do this repair use microscop and small tools so you don`t brake any "angel hair" as is made of thin thin gold.
  6. The Following 26 Users Say Thank You to soxten For This Useful Post:
    antwnhszr (4th January, 2019), barsoom (26th April, 2019), BlacksunLE (7th April, 2017), borshch (8th April, 2017), buga37 (2nd August, 2016), cklair (9th October, 2014), Donabe (19th May, 2018), elecautocr (31st July, 2014), foxibg (1st March, 2016), gameiruz (5th October, 2016), Hayssam1 (12th August, 2015), ista74 (25th February, 2016), ivica21 (6th January, 2016), martinracing (10th November, 2014), martinsixto47 (7th July, 2021), mexanico1971 (25th September, 2014), mohamedkey (12th July, 2015), monir1999 (17th August, 2023), MV auto (11th March, 2016), nedved59 (28th February, 2016), nick_f (19th April, 2018), pezao (19th March, 2015), salimscan (20th April, 2018), shirokov (23rd October, 2014), Timppasa (9th October, 2014), tu329 (5th March, 2015)
  7. #4
    soxten's Avatar
    Mar 2013
    BMW 730 E38 ABS unit with fault that abs pump is running all the time
    http://www.digital-kaos.co.uk/forums...-motor-386926/
  8. The Following 4 Users Say Thank You to soxten For This Useful Post:
    Bkjauto2010 (4th June, 2016), carteknik (8th July, 2020), mexanico1971 (5th November, 2014), PierreTheron (11th March, 2016)
  9. #5
    soxten's Avatar
    Mar 2013
    On Volvo S/V70 97-00 it often get fault as
    "ABS sensor left broken"
    "Flashing ABS light in dash"
    "No communications"
    And this is bad solder, so remove abs unit and open it up.
    resolder all bigger solder points on pcb and it start to work agin.
  10. The Following 4 Users Say Thank You to soxten For This Useful Post:
    carteknik (8th July, 2020), line44 (28th September, 2017), mexanico1971 (9th October, 2014), PierreTheron (9th February, 2016)
  11. #6
    soxten's Avatar
    Mar 2013
    Here is Vw Polo 02-05 ABS 6Q0907379E thread.
    http://www.digital-kaos.co.uk/forums...w-polo-302756/
    If someone has the password protected file from this thread please share without password.
  12. The Following 2 Users Say Thank You to soxten For This Useful Post:
    carteknik (8th July, 2020), PierreTheron (9th February, 2016)
  13. #7
    soxten's Avatar
    Mar 2013
    Help!
    On Vw Golf V it is usual that abs system fault "G201 presure sensor 01435" is broken.
    This is from a Golf 1,6 2008 with pressure tire controll
    Complete unit is 1K0614517AF
    OEM Vw i selling a reparations kit as named 1K698517B for 340 euro.
    Do any know how to repair this presure sensor?
    ABS unit is called ATE/Teves Mk60
  14. The Following 2 Users Say Thank You to soxten For This Useful Post:
    Richi2022 (18th August, 2024), shadab (25th November, 2014)
  15. #8
    soxten's Avatar
    Mar 2013
    Here is the G201 presure sensor in the alu.block?
  16. The Following User Says Thank You to soxten For This Useful Post:
  17. #9
    MACEDONIA
  18. #10
    soxten's Avatar
    Mar 2013
    Volvo S70/V70 1997-2000 ABS unit
    This is a 9496946 ATE unit and has common faults as no connection or left abs sensor bad.
    Open plastic cover with a Dremel mini grinder and resolder connection points on pcb.
    With microscope you can see very bad broken solder points
  19. The Following 3 Users Say Thank You to soxten For This Useful Post:
    gomarota (12th February, 2015), PierreTheron (19th August, 2014), xifly18 (11th December, 2015)
  20. #11
    soxten's Avatar
    Mar 2013
    Here is "G201" brake pressure sensor
    It is a hell to take a way, but with special tools it's ok.
    Where can I buy this pressure sensor?
  21. The Following 5 Users Say Thank You to soxten For This Useful Post:
    delio78 (18th May, 2017), diag1001 (13th October, 2014), mexanico1971 (25th September, 2014), PierreTheron (9th February, 2016), yahya12 (15th August, 2017)
  22. #12
    soxten's Avatar
    Mar 2013
    Someone???
  23. #13
    mexanico1971's Avatar
    portugal
    Hi !
    I do not know were to find that part , but the square Pic, is a code of the part number !
    there are some phone aplicacion to give full designation of the part !
    good luck
    BR
    My work is my life ART TECH GARAGE
  24. #14
    Feb 2010
    Anyone that knows where to buy this sensor? Alot of ABS units have this one
  25. #15
    soxten's Avatar
    Mar 2013
    Here is a ABS unit to Opel Vectra B
    TRW 13216601
    S108196002L
    See my pitures how to open.
    This get bad solder points as I show.
    Resolder and seal top hood back on abs unit and run
  26. The Following 13 Users Say Thank You to soxten For This Useful Post:
    alessio93 (26th February, 2017), antwnhszr (4th January, 2019), CentralinasPt (23rd October, 2015), florinyes (15th March, 2017), Hayssam1 (12th August, 2015), houdiag (24th October, 2016), ivica21 (6th January, 2016), line44 (28th September, 2017), mexanico1971 (5th November, 2014), Mr Mo (16th October, 2016), PierreTheron (9th February, 2016), Stelaras (24th November, 2017), Xro78 (21st November, 2016)
