Results 1 to 12 of 12
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    Question VAG K+CAN COMMANDER 3.6 HELP
    Hi been using vag k+can commander 3.6 for dtc's the only problem its half in broken English and the rest in German but translated by a Chinese person to German so if I use Google translate it cannot as its not translated to German very well so gives you a load of crap.
    does anyone use any software that works with this cable that's in English.
    was going to pay out for a decent setup but off sick now and funds are tight.
    software if anyone can change to English would be fantastic.
    VAG_K+CAN_Commander_v3.6.zip
  2. The Following 2 Users Say Thank You to WOODWARD395 For This Useful Post:
    Joker22 (18th October, 2020), noroforo (1st March, 2025)
  3. #2
    smokey08's Avatar
    Essex, UK
    You have brought the wrong cable for reading faultcodes. It is only good for reading pincodes + mileage correction on ancient VAG cars.
    Get yourself VCDS. (if things are really tight a clone cable with slightly older software costs about ?15)
  4. The Following User Says Thank You to smokey08 For This Useful Post:
    WOODWARD395 (10th August, 2014)
  5. #3
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by WOODWARD395 View Post
    In English tested mate.
  6. The Following 3 Users Say Thank You to super jumbe For This Useful Post:
    Meat-Head (29th July, 2014), noroforo (1st March, 2025), WOODWARD395 (10th August, 2014)
  7. #4
    smokey08's Avatar
    Essex, UK
    Faultcodes still in ze deutsch SJ.
    You could waste your life converting hex to decimal and writing faultcodes in english into the VAG.txt file
    e.g. Faultcode 17645
    17645 convert to hex = 44ED
    Change: "44ED Einspritzventil Zyl.1-N30 Unterbrechung" to: "44ED Fuel Injector Cyl.1-N30 Open Circuit"
  8. The Following 2 Users Say Thank You to smokey08 For This Useful Post:
    Meat-Head (29th July, 2014), WOODWARD395 (10th August, 2014)
  9. #5
    Livingstone
    Mine working in English ok, maybe they need to change computer language!!
  10. The Following User Says Thank You to super jumbe For This Useful Post:
  11. #6
    Oct 2012
    hmm.....german cars....germans dtc
  12. The Following User Says Thank You to betrescudan For This Useful Post:
  13. #7
    speedy100's Avatar
    Athens
    What cable is this working with as I have version 2.5 and it works with Blue "VAG K+ CAN" cable.
    Or VAG KKL+ bue adjustable cable but version 3.6 does not see them...
    Any ideas?
    Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  14. #8
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Quote Originally Posted by smokey08 View Post
    VAG Error Code: 17645
    EOBD II Error Code: P1237
    Fault Location:
    Fuel Injector for Cylinder 1 (N30) - Open Circuit
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Poor engine performance.
    Fuse for injector.
    Wiring harness issue.
    Failed injector.
    Failed Engine Control Module (ECM).
    Possible Solutions:
    Inspect fuse for injector.
    Inspect Wiring/Connector(s) to and from injector, see repair manual.
    Ohm test injector, replace if needed, see repair manual.
    As taken from my EOBD II Fault Codes software which you can Google.
    Keith
    2010 Golf GTD (170)
  15. #9
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by Keithuk View Post
    [/SIZE][/FONT][/LEFT]
    Looks to me like it was stolen from the rosstech wiki.
    Do you have permission to copy their work?
  16. #10
    Manchester UK
    Quote Originally Posted by super jumbe View Post
    my pc keeps deleting it as it says it is a virus. When I eventually got it to install still in German.
  17. #11
    Manchester UK
    Cannot find any cheap cable for vcds that does mk 5 golf 2006 only up to mk4 or am I missing something.
  18. #12
    speedy100's Avatar
    Athens
    Any ideas?
    Best Regards
