Results 1 to 10 of 10
    soxten's Avatar
    Mar 2013
    Default Seat Leon 2011 VDO Dash pinout
    Here is pinout for Seat Leon 2011 VDO Dash
    1 blue connector.
    Can Low = pin2
    Can High = pin 18
    +(plus)= pin 32
    -(minus)=pin 33 and pin 16
    Fvdi can read all info in dash.
    Dash info:
    1P0920810L
    V03
    Made date 2010-07-13
  2. The Following 6 Users Say Thank You to soxten For This Useful Post:
    capi (9th March, 2019), ELAB014 (23rd February, 2016), lush29 (16th October, 2016), omarino (13th April, 2017), urcarpc (11th February, 2023), yugo45 (30th July, 2014)
  3. #2
    Jul 2012
    Hello friend
    Can you tell me please what emulator need this dash from leon 2007 for the CAN ??
    I want to test on the table
    soxten's Avatar
    Mar 2013
    Use obd computer to do test.
    Skickat fr?n min iPhone med Tapatalk
  5. The Following User Says Thank You to soxten For This Useful Post:
    eltiobarbas (15th October, 2016)
  6. #4
    Jul 2012
    Hello friend
    can you explain a little better how to start the dash on the bench
    I have and fvdi 2015 and vcds and odis
    I have the same dash with the same socket
    For CAN H-L want emulator as for example in Reno dash or direct connection from fvdi 16 obd plag to in the dashboard slot
    direct connection is enough
  8. #6
    Junior Member Daruse's Avatar
    Feb 2018
    Hello, how is it possible that GND is 16 and 33 if this plug only has 32pins?
    does anyone have pinout?
  9. #7
    eprst's Avatar
    Jul 2011
    Russia
    Hello. I need to pinout this dash, does anyone have pinout?
    THANKS + REP if I help you
  10. #8
    Jan 2017
    N/A
    Tested pinout for part number 1P0920810F VDO whith NEC 2009+ UDS
    Blue connector 32 pin:
    PIN 7 IMMOBILIZER COIL
    PIN 8 IMMOBILIZER COIL
    PIN 16 GND
    PIN 20 GND
    PIN 28 CAN HIGH
    PIN 29 CAN LOW
    PIN 31 +12
    PIN 32 +12
    Enjoy!
  11. #9
    Nov 2018
    Quote Originally Posted by SALAS View Post
    PIN 16 GND
    PIN 20 GND
    PIN 28 CAN HIGH
    PIN 29 CAN LOW
    PIN 31 +12
    PIN 32 +12
    Enjoy!
    No k-line?
  12. #10
    Nov 2018
    2 - Fuel gauge, -empty 1-
    3 - Fuel gauge, -full 2-
    4 - Fuel gauge, -empty 2-
    5 - not used
    6 - not used
    7 - Transponder 1
    8 - Transponder 2
    9 - Speedometer signal output
    10 - not used
    11 - TOG
    12 - not used
    13 - not used
    14 - not used
    15 - Worn brake pads
    16 - Earth terminal 31
    17 - Clean water
    18 - Coolant level low indicator K28
    19 - Exterior temp. sensor
    20 - Earth sensors 31
    21 - not used
    22 - not used
    23 - not used
    24 - not used
    25 - Handbrake
    26 - Brake
    27 - Oil pressure
    28 - Can instrument panel High
    29 - Can instrument panel Low
    30 - not used
    31 - Ignition terminal 15
    32 - Power supply, terminal 30
    How connect it to VCDS on table? CAN only?
