hi my friend, i have a problem with my car, its an Audi A4 B6 1.8T BEX.
well, the car was WATER SUCK! so after 18 months. we can start the engine, but...
First problem, immo block engine, so yesterday i remove immo from 95040, but... dasboard doesnt show rpm, fuel level, temperature and oil pressure warning on fis.
i test with another ECU immo off, dashboard works OK with this one.
Here you have my last scan
VCDS Version: Release 12.12.2
Data version: 20140212
Thursday,31,July,2014,21:14:55:12785
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAULC68E14A275199 MISSING MILLEGAGE HERE!
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 909 518 AT HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0004711
Shop #: WSC 78901 281 394790
VCID: 820B1AF0DE3E600E0D3-5122
1 Fault Found:
18056 - Powertrain Data Bus
P1648 - 004 - Failure
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04475
Shop #: WSC 06435
VCID: 2643E660C2D6FC2EC1B-50E8
3 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
18258 - Powertrain Data Bus
P1850 - 35-00 - Missing Message from ECU
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1324
Coding: 00001
Shop #: WSC 63351
VCID: 60CFB078E072521EFB7-5122
2 Faults Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 01011
Shop #: WSC 63351
VCID: 3561312C0F7087B6781-4AE4
8 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
57-00 - Electric Circuit Failure
01498 - Bulb for Parking Lamps; Right (M3)
01495 - Bulb for High-Beams; Left (M30)
01499 - Bulb for High-Beams; Right (M32)
01496 - Bulb for Fog-Lamps; Left (L22)
01500 - Bulb for Fog-Lamps; Right (L23)
01493 - Bulb for Blinkers; Front Left (M5)
01497 - Bulb for Blinkers; Front Right (M7)
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 3E732E006A4644EEA9B-5122
1 Fault Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenks?ulenmodul 0611
Coding: 01041
Shop #: WSC 63351
VCID: 3E732E003A4644EEA9B-4AFE
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
VCID: EBD5575499B48146DE5-5104
No fault code found.
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortger?t T7B 1512
Coding: 07790
Shop #: WSC 05007
VCID: 72EBCA303E9ED08E9D3-4AE4
Subsystem 1 - Part No: 8E1959801B
Component: T?rsteuer.FS BRM 0103
Subsystem 2 - Part No: 8E1959802B
Component: T?rsteuer.BF BRM 0103
Subsystem 3 - Part No: 8E0959801A
Component: T?rsteuer.HL BRM 0204
Subsystem 4 - Part No: 8E0959802A
Component: T?rsteuer.HR BRM 0204
1 Fault Found:
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 E
Component: concert II NP2 0410
Coding: 01201
Shop #: WSC 04867
VCID: 2959ED5CD3C8D356EC9-5074
3 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
01305 - Databus for Infotainment
End ---------------------------------------------------------------------
So, today, i compared the last scan with of my ecus and saw that, the last vagcom log doesnt show milleage.
