Results 1 to 3 of 3
    Aug 2014
    Default Need some help regarding USB Loader GX on Wii - Initialize USB Device
    Hello Digital Kaos!
    I've come here because I'm on my last straw, trying to figure out what's causing my Wii to do this..
    Anyways, I followed this guide today on how to mod my Wii (https://www.youtube.com/watch?v=-bxhHXfeXgs).
    I completed everything that was shown in the video and everything turned out just fine.... that is, until towards the end.
    I used WBFS Manager first to load an ISO onto my flash drive. Plugged the flash drive into the console, (yes, I plugged it into the port towards the bottom of the console while it's laying horizontally) and booted up USB Loader GX. The process started up but froze at "Initialize USB device". I thought this may have been something to do with WBFS Manager, so I re-formatted the USB stick to FAT32 and used Wii Backup Manager to convert the game's ISO file into WBFS. (Yes, I have created the "wbfs" folder on my flash drive and stuck the contents into there.) Anyways, I went through all that jazz and finally stuck the USB stick into the Wii for a second time. Booted up USB Loader GX and got the "Initialize USB Device" screen freeze.
    Not sure where to turn at this point, I'm hoping one of you have a solution to my problem because I don't really know where to turn now.
    If you need any extra information from me, feel free to ask. I checked the USB compatibility page and didn't see my flash drive on there, but if you're wondering, this is the flash drive I use..(Lexar JumpDrive TwistTurn 16GB USB 2.0 Flash Drive Model LJDTT16GASBNA - Newegg.com)
    Below is a sysCheck report:
    SysCheck v2.2.0 HD Edition by Double_A and R2-D2199 JoostinOnline Nano
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Priiloader installed
    Drive date: 02.13.2007
    Homebrew Channel 1.1.2 running on IOS58
    Hollywood v0x11
    Console ID: 120509806
    Console Type: Wii
    Shop Channel Country: United States (49)
    Boot2 v4
    Found 77 titles.
    Found 56 IOS on this console. 6 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug ES Identify Flash Access NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS236 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
    Report generated on 08/17/2014.
    Anyways, hope someone can help me out here. Thanks!
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Welcome to DK.
    I see you have SysCheck v2.2.0 HD Edition which isn't an official update sysCheck19 is the last one.
    I don't see much wrong with that sysCheck so I would say you flash drive may not be compatible. You better of using a mains powered USB drive as they hold more games.
    That sysCheck is similar to mine sysCheck #MKWDueNa and all my games work of a powered 1TB USB drive.
    Do you have USB Loader GX on the Wii menu and have you tried the other 2 USB Loaders CFG USB Loader and Wiiflow?
    Keith
    2010 Golf GTD (170)
  3. The Following User Says Thank You to Keithuk For This Useful Post:
    Darney (18th August, 2014)
    Aug 2014
    Hello Keith,
    I took your advise of installing WiiFlow and that was what confirmed to me that my USB Drive was not compatible. I managed to scavenge another USB Drive from around my house and tested it with USB Loader GX. The new USB Drive actually got past the "Initialize USB Device" screen and was recognized. Thanks so much for your help!
