Results 1 to 15 of 18
Thread: Volvo v50 1.6d
    DK Veteran gedas8899's Avatar
    Dec 2010
    Scandinavia
    Default Volvo v50 1.6d
    Hello, i have problem in ecu (bosh edc16c24)memory i have error, 5840 internal fault eeprom cheksum error, what problem can be?
    and car in limp mode no more 3000rpm.
    pawliukazz's Avatar
    Jupiter
    Read eeprom 95160 or 95320 and post the dump here, someone will definitely help you.
    Regards,
    pawliukazz
  3. The Following User Says Thank You to pawliukazz For This Useful Post:
    gedas8899 (22nd August, 2014)
    Dec 2010
    Scandinavia
    her is eeprom
    sometimes they say eerpom error but it actually the flash that has a bad checksum.
    when did did happen? out of the sudden?
  6. The Following User Says Thank You to ominimicu For This Useful Post:
    Dec 2010
    Scandinavia
    i get car with limp mode becouse they cut off dpf, take out ecu from car and somebody before try to read with bdm and broken bdm pins, so no possible read origianl, i geted from second hand exatly same ecu and write eeprom from original ecu, then send flash to my tuner he make chip and dpf off, then i get this error, put back original ecu and get same errors, if it posible something changed in cem, but car is start but in limp mode.
  8. #6
    read yor current file via OBD and post it pls
  9. #7
    which flasher supports 1,6l bosch ecu over obd??
  10. #8
    Dec 2010
    Scandinavia
    readet bdm flash and eeprom readet first time from original ecu.
  11. #9
    that file is bad ..ouchh no checksum blocks....problem is in flash
  12. The Following User Says Thank You to ominimicu For This Useful Post:
  13. #10
    Dec 2010
    Scandinavia
    what can you advice me i dont have idea how fix, with this flash is no errors.
  14. #11
    give me exact ecu numbers u need a new BDM file!
  15. #12
    Dec 2010
    Scandinavia
    I found original ecu file write to ecu, and no errors now, but it shod shows about dpf filter becouse is cuted out, and when press acselerator rpm gose till 3000 and stop.
  16. #13
    then u need a good DPF off solution!
  17. The Following User Says Thank You to ominimicu For This Useful Post:
  18. #14
    Dec 2010
    Scandinavia
    I hope my tuner make this
  19. #15
    Quote Originally Posted by gedas8899 View Post
    ominimincu can do it for you
    he is a good tuner
