Results 1 to 9 of 9
    Romania
    Default Smart fortwo automatic /manual gearbox
    Hello to all , i need help with coding this function in transmission .Car is 450 0.8 CDI with manual shifting . Customer change gear lever with one from automatic gearbox wich has that small SWITCH on the left side , on LHD car .Now i need to adapt somehow that switch . I try to change flash dump from ecu(using galletto 1260) ,R/W was ok but no change .Please advice in this issue .
    Bosch EDG15-C1 0281010161
    1037351599
    CRG/D07
    D7as01M
    Thank you
    the code is not in flash is in eeprom
    Romania
    Hello thanks for reply , i will read the eeprom and post dump for modify
    autocargo's Avatar
    I think you will need Star and Tan code to adapt auto shifting...
    Romania
    Hello , i don't have Star is not possible only via eeprom ???
    Nov 2012
    smartville in front of a OBDplug
    Quote Originally Posted by autocargo View Post
    star is not needed for coding engine things like key or gearshifting and ac softouch
    it can been done in eeprom file without tan
    Romania
    Quote Originally Posted by kennfeld View Post
    Hello again , i attach eeprom file 95P08 .Can someone please activate that function
  8. The Following 2 Users Say Thank You to cosmin12345 For This Useful Post:
    krikeur (6th March, 2019), mcday (18th November, 2017)
    Nov 2012
    Ok i have dl but diesel i have no database and no car
  10. #9
    DK Veteran wsc's Avatar
    GR
    Quote Originally Posted by cosmin12345 View Post
    Tomorrow I will modify for u mate , tomorrow till the afternoon
    Smart car engineer ,
