Results 1 to 3 of 3
    Oct 2010
    EU
    Default SIM210, Ford Fiesta 1.4 - virgin or immo off
    Hello all,
    is it possible to virginise or immo off this used ECU:
    Ford Fiesta 1.4 59KW
    SIM210
    4S61-12A650-NB
    S120977013 C
    3BTB
    29f400 + 93c86 attached
    Many thanks in advance
    Oct 2010
    EU
    there is no possibility to make virgin?
    Original ECU is broken, i bought used ECU and need this used ECU use in this car. But how? It is not possible to read original flash, only original eeprom. So i can not clone.
    How to solve this problem?
    attached eeprom from original ECU.
  3. The Following User Says Thank You to Pali33 For This Useful Post:
    johnie-9 (5th February, 2015)
    here
    if it the same ecu wit ori one you dont need the flash only the eeprom, try to swap it or read & post 25320 from dash for synchro.
  5. The Following User Says Thank You to smt For This Useful Post:
    Pali33 (5th September, 2014)
