Results 1 to 14 of 14
Thread: 2010 bmw 535i
    DK Veteran highrisk's Avatar
    Default 2010 bmw 535i
    I replaced the chip on this one and the center Guage that shows the miles does not light up.. chip was d80.... and now is 35080-vp... any help would be thankful
    carbandit's Avatar
    bonnie scotland
    check ribbon connector probally be this if eprom is on correctly of course
    Thank you I will check it again
    Quote Originally Posted by highrisk View Post
    Please tell with some details & about tools you used ..
    35080 eraser clone and Dp3 to program. I had just got it.. I believe I did it right...will check everything again
    Does anyone have the pin outs to fire it up on the bench
    Jul 2013
    some vp chips wont write if wrong voltage selected use new 35080 you wont have any problems
    Dec 2010
    You talking about f series?
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Cool
    Here you go power up dashboard on table
  10. The Following User Says Thank You to cokolo For This Useful Post:
    nomis (10th September, 2014)
  11. #10
    Thank you..very much
  12. #11
    ibratex's Avatar
    Jul 2015
    angola
    hello mate did you do cas with 35080 ereaser clone ?
  13. #12
    dashradio's Avatar
    Inafield
    Quote Originally Posted by ibratex View Post
    The answer to that would be NO,
    How could a 35080 eraser do a CAS ?
  14. #13
    ibratex's Avatar
    Jul 2015
    angola
    http://www.ecutool.com/Universal-EEP...-CAS_8090.html
    It's multi function mate
    Sent from my SM-G850F using Tapatalk
  15. #14
    Nov 2015
    getting that ribbon cable set correctly to get the cluster to read right is no easy task sometimes . try pushing gently on the ribbon while looking at the cluster. Sometimes things start to roll into veiw with this to show it is ribbon set incorrectly.
