This is now VGS1 (VGS-NAG2)
Yes you can read it via BDM port like EDC16 (same platform)
Can someone confirm?
Hi guys , has someone tested the BDM reading of the VGS2/VGS3 TCM ?
Hello can i update software on my vgs3 sw 0029020300 via fvdi+database
good job,That is what I need
pinout is wrong
jarbo3a (16th August, 2021)
I have a problem with the 722.9 board when the cold car then goes only at second speed as it warms up after 15 min drive all goes normal, all the sensors are ok for diagnosing me getting out that the voltage is weak on the board but when i measure the voltage is ok or a faulty communication between the board is faulty and I have verified that the communication is ok, whether the replacement panel or some other solution is left .. thanks vgs2 nag2 is the board
if I buy a new board, can it be programmed with this tool https://www.ebay.com/itm/Original-FV...-/323255888516
Hi mate great job! You got solution for this tcu?![]()
Another processor - you can read/write it by JTAG - but you cannot simply access external eeprom memory. So fastest and working way is use boot-mode, upload your code and execute.
khoums (7th May, 2022)
hello help my pliz need VGS2 can pinout realy need.
Hi DK
I have this TCU A005 446 37 10 K05
11088647 23.08.16
VGS2-FDCT from Mercedes b180. If enyone have Good Original eeprom + flash or Virgin files?
Probably the eeprom file is corrupted
I appreciate your help
Nick
VGS2-FDCT.rar
