hello friends. I need to know which tool I can to read a delco ecu e83 agile Chevrolet / Opel. or if I can read on the bench with fgtech eu v54? someone with the wiring diagram/photo.
thank you very much.!
Kess can read this car
Don?t forget to mark "Thanks" if I helped you
fgtech v54 clone?
ascotauto (19th September, 2018)
delco_e83_pin_ecu.jpgdelco_e83_boot.jpg you select boot MPC55xx, FG-TECH clone no check-sum correct! add reputation!
ecufix (13th December, 2023)
HOLA YO HICE CON LECTURA KESS EN LA ESCRITURA HAY UN ERROR NO DEJA HACERLO TENGO EL ARCHIVO ORIGINAL GUARDADO Y EL ARCHIVO DE RESPALDO PARA ESTE
Y ESTAN COMPARANDO EL LOG EN ALIENTECH PERO NO HAY RESPUESTA ESTA GENERACION DE ECU NESECITA DE PROGRAMACION DE VIN Y ... PARA PODER HERMANAR ESTOY EN LO CORRECTO?????
Hi!
I try read this ecu by galletto4 and when i push connect, after 90% stop "error go_sub" and "error setup" i use resistor 4,7k. How can i fix it?
Same problem, Galletto4 V54, Win7, BDM/JTAG. “Connect” stops at 90% with time-out. Any suggestions what should I do?
Can I get the above published JPEG file to download in readable resolution?
Here in better resolution
mexanico1971 (3rd October, 2019)
Czy czytałeś komuś? na galletto
i read a d write this ecu without problem with kess v2 5.017 and ksuite 2.47
Enviado desde mi LG-D855 mediante Tapatalk
Could you say how you do it? According to the instructions, ktag can not read.
IO terminal can do it
alfanacleto (4th October, 2019)
[QUOTE = RomanBoski; 3512054] ¿Podrías decir cómo lo haces? De acuerdo con las instrucciones, ktag no puede leer. [/ QUOTE]
