hi there dear members. I have a Mercedes w202 c230 compressor. vin nr. adb2020246f690086 engine nr. 11197560009429. vehicle initially had key problems. has been standing for 6 months. add fresh fuel. after key were fixed, vehicle started and revved up, after a few starts the vehicle refused to pick up the revs. car idling fine. changed fuel pump and filter. fuel pressure around 3.5 bar at fuel rail. scanned vehicle, only brake light switch fault. unplugged airflow sensor, no difference and no idling. removed injectors, had them tested all fine. airflow sensor life data shows fine, friend scanned car using star. intake air temp fine, coolant temp fine. changed fuel pressure regulator. checked all fuses. fine. could some kind member please advise on what else I can check on car. many thanks in advance. keep well.
