Results 1 to 9 of 9
    Apr 2014
    Default Openbox sound no picture
    Hi folks, a friends openbox v8s has been working for 3 days then all of a sudden gone to a blue screen with sound but no picture.
    bizzarely i brought the box to mine and it worked fine first time. Also, his sky works through both hdmi slots on his tv, and ive switched the hdmi cable but open box to the tv is just blue.
    his tv is a technika if that helps
    any ideas guys and gals?
    Oct 2008
    Have you adjusted the setting on your box to his TV. ( ie 720 or 1080)
    Apr 2014
    No, just did basic unplug repluf try somewhere else etc....
    So try changing from 1080 to 720 may do trick?
    Apr 2014
    Any other reccomendations folks? Cant be arsed going back if that isnt it
    Hadron's Avatar
    Nov 2012
    E. London
    As sexysam says try some different video resolutions.
    Connect his box to his TV using scart or composite RCA (phono) connectors. Hopefully you will then see a picture & can see what you are doing in the menus.
    Jan 2014
    possible faulty hdmi cable ,i had one once its rare but possible
    Apr 2014
    Scart worked!
    is the option to change from 1080 to 720 on the openbox (and if so where) or the tv usually folks.
    also, thanks to everyone for the help!
    Apr 2014
    V.format button - found it, working fine :-)
    all
    Hadron's Avatar
    Nov 2012
    E. London
    You can also find it in Menu > system setup > TV system > video resolution.
