Results 1 to 5 of 5
    wiseman's Avatar
    Default VOLVO C30 DPF Removal ECU ERROR?
    I Removed Volvo c30 DPF 1.6D EDC16c34 and after has the fault code 7700 which was removed manually, Problem is I have had an Anti skid fault Ever since. And Engine light still appears after some time
    In anti skid it says communication fault with ECM, i have checked for broken Wires etc... but nothing.
    Ive seen other people mention this problem on this volvo forum after DPF off was made.
    Chk was calculated using genuine OLS and FGtech for BDM
    Do i need to sync ABS or CEM or something?
    wiseman's Avatar
    Jun 2012
    Italy
    how do you delete dpf?
    i delete by bit switch and 2 zeroed maps, plus some dtc deleted. EGR in the "common" way.
    I write with bdm fgtech and it correct check in writing.
    never had that problems, and i did a lot of V50 and C30 1.6D
    try original file
    Dec 2018
    I have similar problem on a car that came in with DPF already off After restoring to ORI, & fitting new DPF system, same 7700 code & in limp mode. ADM( Eloys Fluid System) showed codes but reset tank level & they cleared okay. Has anyone managed to kill the 7700 code & got car running successfully ? maybe some eeprom mod ? I am not sure on ADM fluid level , maybe it needs to be full when i reset it ?
    Oct 2014
    Latvia
    7700 dont call limp mode or any other issues.
