Due to unsuccess using search Button i Open this thread.
How To Program Remote Key For Nissan's whose use this key:
Immo Programmed Succesfully, but Haven't Found any way to make The remote Working,
Fcc ID: CWTWB1U751
thanks to all members.
Fcc ID: CWTWB1U751
Work SmarterNot Harder
1. Close all doors.
2. Lock doors with drivers side power door lock switch.
3. Insert the Key and take out the Key 6 times.
4. Doors will UNLOCK.
5. Turn Key to accessory position.
6. Lock doors with drivers side door lock switch.
7. Press button on remote control.
8. Remove Key and check operation.
buga37 (18th December, 2014), datapage (8th April, 2016), pezao (26th November, 2014), viejomatius (25th November, 2014), whiskeyman (25th November, 2014)
Today just had chance to test again the Procedure, Everything goes OK Till step #4, After step #5 the procedure doesn't work and new remote doesn't program![]()
maybe u did not have the correct key or if is a late model vehicle u need the diagnostic tool .
cj
viejomatius (30th January, 2015)
You can also try skipping 4 and 6
Does the hazard light flash to show its gone into progrmaming mode after completing step 3?
Try this solution . Works all Nissan except Id46 models .
Switch Ignition Off – ON 6 times within 10 seconds
Do not remove key from ignition
After 2 seconds indicators will flash twice
Programming mode is activated for 2 minutes
Press and hold unlock button
Press lock button 3 times
Release unlock button
Indicators should flash once to indicate correct programming
Repeat procedure for remaining remotes
Switch ignition on – indicators should flash twice
Programming mode deactivated.
no, The Hazard Lights don't Flash, Just all the doors unlock. Good idea, i Will try at next chance![]()
Key was From the dealer, i guess should be the correct remote, dear cj If the remote would be programmed by diagnostic tool, is normal that the manual prodecure works fine till 4 step?
This are the missing steps.....
-4 jump on one leg around the car..CLOCKWISE !
-3 relax
-2 remove car battery for 5 to 15 minutes(depends on how much time will take next step)
-1 have a cofee
Now you can start with steps 1 to 6....
If this doesn't work don't worry there is always tomorrow ....
A failure will not appear till a unit has passed final inspection
hi check this video via diagnostic , http://www.keydiy.com/13-video/p-001-1.asp?id=1198
not sure why the manual way not work .
cj
viejomatius (31st January, 2015)
