hallo to all
need conection and sucirity byte to read this mcu by x prog
best regards
hallo to all
best regards
Hi.
This is picture taken from one of Russian forums - X-prog connections for MCU MC68HC08AB16 with mask 0l72A as for example ople immo2. You should set MCU clock speed in Xprog software from 4Mhz by default to 8Mhz.
hope it will help you
BR
Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
obeids (22nd March, 2016)
Xprog not request security byte for reading? Upa when read bytes security if necessary, otherwise the reading is ADADADADADADADADADAD
GREETINGS
Difficult, time consuming and dangerous lifting, leg mcu.
Unsolder immo 1 minute.
welding plate 1 minute.
Unsolder plate 1 minute.
welding immo board 1 minute.
make pcB circuito
F3-B1-F3-AB-F3-A5-F3-9F
yui (9th June, 2015)
alefabi2006 (6th December, 2014)
I'm thinking this way is more convenient.
A topic that interests me
