Results 1 to 7 of 7
    Default How to clear Nissan/Infiniti DTC P1610 NATS locked immobilser?
    I need info on how to clear this code. In the past when a customer has tried to start the car with a non transponder key it will lock the immo. A programmed key must be cycled three times again to get the car to start. I cannot clear the P1610 trouble code with my Maxisys. I've been told to leave the key in the on position hooked to jumper cables for 1 hour and that should clear it, but no luck.
    Customer has to take it to a Nissan dealer and they can clear it. What are they using? Will the Consult 1,2,3 or 4 or AVDI or any OEM or chinese tool clear this one code?
    Meat-Head's Avatar
    Err use search button, on this one, what's the story morning glory.
    A search of DK and other sources give 3 options. Leave ignition on for 1 hour or disconnect battery or use existing programmed key and cycle 3 times. I have tried option 1 and 2 with no luck and 3 is not an option when customer has lost all keys. I do not see a 4th option when searching DK.
    rideon's Avatar
    RO
    4th option........
    make new key
    go to option 3
    end
    My mistake...."end" is spelled 'got your money now f@#k off'
    A failure will not appear till a unit has passed final inspection
  5. The Following User Says Thank You to rideon For This Useful Post:
    keysmith (4th December, 2014)
    if see code P1610 - Lock Mode, This code make after five times starting engine without good key or wrong responce from immo box.
    You must start the car, after possible erase dtc via diagnostic tool
    Sep 2014
    u have a problem or in the immo or in the immo connections
    programming in new key didn't help, it was a bad immo ring just replaced it, done
  9. The Following User Says Thank You to keysmith For This Useful Post:
    Phase 4 autokey (14th December, 2014)
