Page 2 of 11 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 161
  1. #16
    Oct 2010
    We has added 2 new modules:
    №39 Nissan / Infiniti petrol - Hitachi K-Line ECUs
    Module allows to read and write full flash of Nissan and Infiniti ECU`s (with K-Line only), manufactured by Hitachi via OBD or on the bench. Checksum recalculation is supported.
    List of supported MCUs:
    SH7054 15N - 384kb
    SH7055 13N - 512kb
    SH7055 20N - 512kb
    SH7055 24N - 512kb
    SH7055 29N - 512kb
    SH7058 21N - 1024kb
    SH7058 23N - 1024kb
    №29 Subaru - Unisca JECS and Hitachi ECUs (with K-Line and CAN bus)
    Module allows to read (full flash) and write (maps) of CPU SH7058 (ECU with CAN bus) and WA12212970WWW (ECUs with CAN bus and K-line) via OBD. Checksum recalculation is supported.
    SH7058 1024К (CAN)
    WA12212970WWW (M32174) 512K (CAN)
    WA12212970WWW (M32174) 512K (K-line)
    Approximate car list:
    Subaru (non-turbo) cars 2003+ :
    Impreza, Legacy, Forester, XV, etc.
    Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
  2. The Following User Says Thank You to Zohar For This Useful Post:
    Gurkanoto (25th January, 2023)
  3. #17
    Mar 2009
    Hello!
    Im using MMCflash too with OP2.0, working very well. Also Bruce Willis is very helpful guy, always answer all of my questions .
    regards
  4. The Following 3 Users Say Thank You to kerekt For This Useful Post:
    antonypaul (6th March, 2015), CLK1201 (17th April, 2015), Zohar (3rd March, 2015)
  5. #18
    Oct 2010
    Hi DK members!
    latest news about MMCFlasher:
    in module 37 (Nissan/Infiniti Hitachi CAN) was added MCU SH7253x (free update for all owners). This MCU is used in latest Infinity (QXxx series) cars, approximately from 2014+
    in module 39 (Nissan/Infiniti Hitachi K-line) was added algorithm of fast reading and writing of MCUs (not for all softwares for now, but covered above 80-90 percent of softwares). For example now: time of reading of MCU SH7058 not above 5 minutes, time of writing - not above 8-12 minutes (on car via OBD).
    BR
  6. The Following 2 Users Say Thank You to Zohar For This Useful Post:
    antonypaul (8th April, 2015), CLK1201 (3rd March, 2015)
  7. #19
    Caribbean
    which module is needed to read/write suzuki denso 33920-057k8?
  8. #20
    Sick world
    can some post here prices overview for this flasher and modules in €?
  9. #21
    Oct 2010
    Quote Originally Posted by S.W.A.M.I View Post
    Hi.
    Module number 36 - Denso CAN
    BR
  10. The Following User Says Thank You to Zohar For This Useful Post:
    S.W.A.M.I (12th April, 2015)
  11. #22
    Apr 2012
    does the nexiq usb link interface work with this software?? is j2534 compatible.
    regards.
  12. #23
    Oct 2010
    Not tested with Nexiq.
    BR
  13. #24
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Will MMCFlash work with AVDI J2534 Passthru?
  14. #25
    Sep 2013
    CAMBODIA
    no i test already dont work
  15. #26
    Senior Member Novik_UA's Avatar
    There no help for tool. You have to find pinout etc. by yourself, or lost time to read a lot on mmc forum to find answer.
    Think tool like that need to have good help base, like ksuite,fgtech or magpro.
    Yes, you always can ask help from developer and he will help for sure, but you lost time and sometimes clients.
  16. #27
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by Novik_UA View Post
    Can you explain why you would need to find pin outs .etc.etc... when the tool works by OBD (find obd socket .. plug in interface .. job done )
  17. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    antonypaul (12th June, 2015), CLK1201 (9th May, 2015), yugo45 (1st October, 2017)
  18. #28
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Maybe when must flashing on the table... e.g. only the ECU was sent for tuning.
  19. #29
    Yes, or if tool can't connect or correct read/write via OBD, or car have weak battery etc. And for me most safe way to read or write is on the bench with good power supply.
    But if you don't now pinout - you must lost your time.
  20. #30
    furburger
    Guest
    №6 Mitsubishi Diesel 2006+ Denso SH7058 (FP-256H, MCU in QFP256 form factor! not BGA MCU)
    Supported cars: Pajero Sport 2.5 DiD, 3.2DiD; Pajero 2.5 DiD, 3.2DiD; L200 2.5 DiD, 3.2DiD; Strada 2.5 DiD, 3.2DiD. Module allows only writing ROM (with CRC recalculation) in ECU Denso with MCU SH7058 (processor in ECU maked in QFP-256H form-factor (not BGA).
    Could the above protocol work on 2013 L200 175ps 350nm 2500cc?
