Results 1 to 15 of 17
    Member shanker1212's Avatar
    Dec 2014
    Default MAGNETI MARELLI IAW 59F.M3 immo off
    please help immo off fiat ecu MAGNETI MARELLI IAW 59F.M3
    the attached photo shows more details
    what chip should i read ? or if there is another way to read the dump without tacking the cover off ?
    i will be glad for any help
    best regards
    Dec 2014
    anybody want to help ?
    jolidj's Avatar
    ITALY
    you need to read 95160 inside ecu. read in boot mode and post it.
    ALL TUNING.
    THE BEST OR NOTHING. THANKS + REPUTATION .
  4. The Following User Says Thank You to jolidj For This Useful Post:
    gogoli (29th February, 2016)
    Dec 2014
    jolidj
    thank you for the info but do you think the BDM100 is good for this ECU , or what do you recommend to read and write this ECU
    best regards .
    DK Veteran sl4ck's Avatar
    No mate, there's some story being this ECU's, what HW have you?
    I can help you, but you have to be more specific
    KTAG, PCMFlash, Galetto FGTech V54, Smok Multitiool UHDS, I/O Terminal, Fiat/Alfa IAW Bosch Decoder, UPA-USB, XPROG, FVDI, Orange5, Renolink, DiagBox, Can Clip, Xentry
    jolidj's Avatar
    ITALY
    you need piasini ore other tool to read eeprom.
    ore specific tool for this ecu do it immo off.
    ALL TUNING.
    Dec 2014
    the ecu is for fiat punto 2005 and has the following written on it :
    IAW59f.M3 /HW023 / 3804-ML4
    12v 081 01
    you can see the photo of this ecu on my first post
    jolidj's Avatar
    ITALY
    SERCH to read ecu in boot mode, you need tool to read eeprom from ecu.
    ALL TUNING.
  10. #9
    Mar 2013
    THAT ECU DONT WORK FOR PUNTO 2005 YOU NEED USE IAW5AF.P3
  11. #10
    You need to buy specific hardware, because your ECU is HW023 (HW < 100), if was HW > 100 you could do it with KWP2000 and modded .dll
    Check PM, i tell you were i bought mine, and worked ok, before that i spended many days reading all information and trying another methods, never were able to boot mode with test point.
  12. #11
    Dec 2014
    our brotherrallyarek is right it is not for fiat 2005 it is for 1999
    thank you for the correction and i am so sorry it is my mistake .
  13. #12
    Dec 2014
    thank you all my friend who participated in solving this issue .
    i decided to buy the IAW59 decoder either the Italian one as original or any clone one .
    wish me luck .
    BR
  14. #13
    jolidj's Avatar
    ITALY
    best way for immo off of virgin .
    ALL TUNING.
  15. #14
    Mar 2013
    So if i virginize ECU and cut immo line all should be fine ? engine start?
  16. #15
    Nov 2015
    Hello! Old post, but I hope I can find help here! I have marelli edu decoder and I'm trying to make immo off on a IAW 59F.M3 HW 303. the tool makes immo off but the car doesn't start. If i connect the antenna the car starts just fine, but after that the ecu is codded again to the car. So it was no really immo off done, even if the tool says "Vergine, Immo OFF". Is there any wire that needs to be cut before starting the car? If so, witch wire do I need to cut to do the job properly. The car is a 2003 punto with body computer not immobox. Thank you!
