Results 1 to 15 of 29
Thread: Peugeot 307 Diesel year 2003 Advice (Economy Mode Active)
    super jumbe's Avatar
    Livingstone
    4,963
    Default Peugeot 307 Diesel year 2003 Advice (Economy Mode Active)
    I have got 203 Peugeot 307 Diesel when engine key turn I get the sign on screen (Economy Mode Active) car will not start, I disconnected ECU and read chip AM29F400BT and tried immo off still the same car does not start, I have come to a dead end.
    enclose 2 files can some one also give me pincode, thanks in advance.
    Aug 2011
    uk
    93
    Quote Originally Posted by super jumbe View Post
    Is it 2.0 hdi?
    Have you got comms to engine ecu? If so any codes?
    Have you comms to bsi? if yes check vin and see if its got a load of nonsense for vin,if so then reconfigure bsi then relearn keys,
    If you got comms then check for power to engine loom, car only saying economy mode because its saving battery power for engine start, your wipers etc.. wont work either, soon as it starts car will come out of economy mode
    edc15 ecu?
    many thanks flyins
  3. The Following User Says Thank You to flyins For This Useful Post:
    super jumbe (30th December, 2014)
    stoyanov's Avatar
    42 75 6C 67 61 72 69 61
    328
    Your car is with engine 2.0 hdi,ecu edc15c2 bosch ref. 0281011081 and for pin code you must read eeprom 95p08 from this ecu.Are you sure about immo problem with this car,did you make any diagnosis to see errors and live data?
  5. The Following User Says Thank You to stoyanov For This Useful Post:
  6. #4
    here
    253
    bad immo off used, this s the right one--------------------->
  7. The Following User Says Thank You to smt For This Useful Post:
  8. #5
    Livingstone
    4,963
    Peugeot 307 2.0 hdi,ECU edc15c2 bosch ref. 0281011081
    This ECU Verson 2 It does not have 95p08 eprom only have eepron AM29F400BT.
    No fault code, I have noticed wippers not working as you have mention, lads I am looking for solution any idea???
  9. #6
    Nov 2014
    5
    Have you checked ckp sensor?
  10. The Following User Says Thank You to QRTPSD For This Useful Post:
  11. #7
    roman_auto's Avatar
    176
    Economy active , it mean that the voltage in the vehicle is low and the bsi give this message and disable the radio,windows and etc...., is not your fault, i will glad to help you but you have to scan it with pps and check pressure of the pump and ecu status.
    If It Helped Push Thanks
  12. The Following User Says Thank You to roman_auto For This Useful Post:
  13. #8
    Nov 2014
    5
    No, in peugeot cars economy mode appears when a security problem is present but also appears when ckp sensor fails
  14. The Following User Says Thank You to QRTPSD For This Useful Post:
  15. #9
    drakov's Avatar
    Aug 2008
    19
    Disable economy mode with diagbox, scan car, post faults, view live data, a non starting car doesnt mean immo problem, I think you are maybe jumping in to deep to start with SJ, as long as it's in economy mode it can disable comms/functions of many modules so before you do anything you need to get it out of that state first to get a better picture, I have a 207 non start in workshop if I have time I will post screenshot of where option is unless someone explains it better, oh and my one wont be fixed with an immo off solution (unless it can re-align the valve timing )
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  16. The Following User Says Thank You to drakov For This Useful Post:
  17. #10
    Jul 2013
    yorkshire
    79
    To get these out of eco mode I have a spare crank sensor, I just wave a wrench close to sensor. 4 to 6 passes usually does it. Make sure battery is charged.
    autoden.
  18. The Following User Says Thank You to autoden For This Useful Post:
  19. #11
    Livingstone
    4,963
    Quote Originally Posted by autoden View Post
    autoden.
    Lads slow down I am well confused now, I having no fault code on my diagnose, do I need to change crank sensor?
  20. #12
    drakov's Avatar
    Aug 2008
    19
    autoden.
    Can you please explain the theory behind this? If you have a working crank sensor what will plugging in another one and triggering it manually do that the already fitted one won't? I only ask because my understanding is these cars only default to economy mode after several minutes of cranking (or anything resulting in low battery output) the reason it comes out of economy mode after starting is due to the charge seen from alternator, at least that is how it was explained to me.
    Economy mode is not a fault it's a battery saving safety feature, usually triggered by leaving ignition on for 2 long or several non start cranking attempts
  21. The Following User Says Thank You to drakov For This Useful Post:
    super jumbe (31st December, 2014)
  22. #13
    drakov's Avatar
    Aug 2008
    19
    SJ until you do a full scan with it out of economy mode imho you will never see a full picture of what's going on as the system shuts down a lot of resources to conserve power, so get that enabled first then rescan the full car.... what are you using for scanning it.... please don't say an eobd scanner
  23. The Following 2 Users Say Thank You to drakov For This Useful Post:
    obdsystems (25th June, 2015), super jumbe (31st December, 2014)
  24. #14
    3
    what do you have bosch or siemens
  25. The Following User Says Thank You to ecu For This Useful Post:
  26. #15
    Livingstone
    4,963
    I have Autoboss PC Max...
