Results 1 to 4 of 4
    roman_auto's Avatar
    Default Fgtech V54 posetive and negative location on the bench cable worng need correct
    Hi guys
    When i connect battery to the white connector with the switch, when i close the switch the wires are getting very hot and i disconnect the battery, the connection is worng of the + and - that i need to supply, can someone upload the correct order of the wires. please it urgent
    If It Helped Push Thanks
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Hi.All pinout is in Documents when you instal fg tech.
    roman_auto's Avatar
    no this connector that goes dierct to the FG is not in the documants, can some one helps and say why the + and - get hot and i mesuard AMP and i get 15A with ecu connected, every ecu i got this number but with obd on bench all work
    It is part of the document FGTech_BOOT_TRICORE_User_Manual.pdf page 12
