Results 1 to 15 of 16
    Fec001's Avatar
    Default Renault Megane 1.9 DTi '99 immo off
    Hi!
    I tried make immo off this car. Follow IUD 3.2 procedure, write immo off file to 24c02, lift up eprom PIN7 and connect that to PIN8, cut immo line pin 59. Result: car doesn't start and now pre glow light lamp is flashing too.
    ECU details:
    0 281 001 969
    As I know there is 100% working solution but never done this car immo off.
    Attachement, there is ori dump and what I tried.
    I need some help!
    blackpirate's Avatar
    Jun 2009
    take out the 24c02 from ecu!! try that!
    If freedom is outlawed, only outlaws will have freedom!!!!
  3. The Following User Says Thank You to blackpirate For This Useful Post:
    Fec001 (6th January, 2015)
    Fec001's Avatar
    OMG!
    Car starts but didn't go for test drive. Will not be problems with limp mode, RPM only 2000 etc etc.... ???
    Thank you!
    gokey's Avatar
    try this file
    PUSH reputation and thanks If you think I helped .............................
  6. The Following User Says Thank You to gokey For This Useful Post:
    Jun 2009
    Quote Originally Posted by Fec001 View Post
    OMG!
    Thank you!
    srry mate
    dont know if such issues will appear!
    if other persons, have a fully tested solution use that ones! if not you can try and leave it with desoldered eeprom!
    all the best!
    bp
  8. #6
    Fec001's Avatar
    Quote Originally Posted by blackpirate View Post
    srry mate
    all the best!
    bp
    Unfortunatelly with desoldered eprom, car went to limp mode
  9. #7
    Fec001's Avatar
    Quote Originally Posted by gokey View Post
    try this file
    Now i'm trying your file. Should I make tricks with eeprom legs?
  10. #8
    Everywhere ............................I'm needed
    use new eprom with WP function ST24c02/04WP and write ff from 40 to 5F
    Money is not everything . . . when you have enough ! ...
  11. The Following User Says Thank You to Topman000 For This Useful Post:
    Fec001 (7th January, 2015)
  12. #9
    gokey's Avatar
    you have info in word file
  13. #10
    Fec001's Avatar
    Why use new eprom? WP: lift pin7 up and connect to pin8?
  14. #11
    yes lift 7 and conect to 8.with an orig.eprom it didnt work.
  15. #12
    Fec001's Avatar
    Ok!! All clear now!! I have only 24c08W6 in my workshop now. Is that ok or MUST use 24c04WP
  16. #13
    tested on 24c02/04WP - write protect
  17. #14
    Fec001's Avatar
    Tried with 24c08W6. Car starts fine but pre glow light flashing on IC and immobilizer fault in ECU. If delete DTC then, flashing stops until next restart. Is that normal?
  18. #15
    on some ecus it is flashing an on some it is not.im solving it just now.if it wont be working i will disconect light.
