Results 1 to 12 of 12
    Sep 2012
    Default hi to all need help we amiko alien mini hd box
    the problem is when i turn box on it just says no signal ie it was working fine then when turned back on .....just no signal ;;;;ive checked the dish and the cable connections all working fine checked with another box ......when i flash box with the firmware it still says no signal ie please help i know its put in skybox threads but no were to ask on here ;[ thanks
    Sep 2008
    so you can see message on screen of tv saying no signal and you can get menu and other stuff up on screen meaning hdmi is working? is it just a channel or all channels as if moved might give you a no signal?when you flashed box did you scan for channels on 28.2?
  3. The Following User Says Thank You to cactikid For This Useful Post:
    seangraves (8th January, 2015)
    Sep 2012
    hi there thanks for reply yes it says no signal on every channel ive try scanning box its not picking any channels up ...ive tried my blade box on the satterlit connection and it all works fine ,,,i can get into menu and scan box etc also tried updating box with firmware ..it still says the same no signal on the snr/% its just reading 5& im stumped on what to try next ps thanks for replying
    Sep 2008
    first of all make sure you used the firmware for that model,dont assume any will do as it may brick it,secondly did you set the sat to scan on 28.2 recheck again as if set to other sat =no signal.might also be a faulty tuner,only way to check is to do it elsewhere to scan.
    how many f connector ports on box 1 or 2 if 2 are you in loop?
    Sep 2012
    thanks again defo faulty tuner mate ;;;ive tried it at two addresses,,,,,is there anyway to fix it or is it bin time ;[
    Feb 2014
    sean u could try factory reset on the box and start from scratch as a last resort but it does all point to a faulty tuner as u av said it was working fine at 1 point.u av nothing to loose with a rest just remember to back things up pal.
    Mar 2009
    Warrington, Cheshire
    I am just testing one of these Micro HD boxes now & it's definitely got a faulty tuner probably like the original poster in this thread.
    It only seems to hold the signal for a few seconds then disappears altogether, have jiggled the cable about a little to see if it's come loose but it hasn't.
    Tried on 2 dishes I know are both working as I have other boxes working fine.
    Did a firmware upgrade but still gave same fault....PILE OF CRAP if you ask me.
    Whereas the better Amiko Boxes (Alien 8900 / Alien 2) never had a problem with signal.
    Jan 2013
    Lads I have found with these boxes that they can be a bit fussy with the type of LNB. If you have a standard Sky dish with quad LNB, it may not work. The problem is you can't just swap the LNB for a standard universal quad as the collar on the fitting is oval shaped (Sky do this on purpose). Only proper solution is to install a 60cm universal dish & LNB. However, that may not be the problem & you might do all that for nothing, but I have found that to be an issue in the past... hope that helps!
  10. #9
    digicon's Avatar
    Quote Originally Posted by Waxer View Post
    I am afraid that is not the Case at all concerning the official $ly dish it is after all ellipitical shaped (Standard everyday offset Dishes are Oval) with there own matching LNB with a feedhorn design shaped to match the dish precisely.
    That is why using a standard LNB on there dish is pointless it will work but the design of a standard feedhorn is such that it is meant to illuminate a standard offset Oval dish and vice versa if you used the $ly quad LNB on an offset oval dish it will not illuminate (Gather Signal) correctly and so your Signal readings would suffer compared to using a matched LNB
  11. The Following User Says Thank You to digicon For This Useful Post:
    rigsby71 (16th July, 2015)
  12. #10
    Mar 2009
    A Digicon says, this is not the problem, I tested Amiko Micro HD on Sky dish & LNB & also on a feed coming from a 1.25 dish on a Technomate gold .1db LNB & still no signal, definitely a tuner fault with this particular box I tested for someone.
  13. The Following User Says Thank You to rigsby71 For This Useful Post:
    digicon (16th July, 2015)
  14. #11
    Nov 2012
    anyone know what the master pin is on mone of these boxes? tried to reflash with rs232 with no luck....
  15. #12
    Sep 2008
    not used amiko but are you sure its done by null modem cable/rs232 and not by usb? have you read the tuts on site?
