I can not try .The car is 450km away.I have mercedes start error program but I'm not sure
it would do it safely.With what you did this.
Hello friend, the File is the same but not success, Car still shows Start Error,,,,,,,,,Any idea???
regards
HI friends
Someone can take a look one my dumps please !!!
http://www.digital-kaos.co.uk/forums...-to-fix-please!
Press "THANKS" button. just one click, CHEERS
Hi Germanml, damp from lupu sandu not working ? Please put it here I want to check something.I have several programs that do this but I'm not sure of any.
Sorry sarkan,I think you have to ask pass Lupu,,, ,, File didn't work for me,,
regards
germanml: Solution is well tested so far. Please check you WSP with diagnostic equipment. Check if key is ok, or WSP is proper powered. In most cases you get fuse 7 (AFAIK) burned.
hello Lupu, yesterday I checked Fuses and 12 volts feed, I think it could be wrong key, I will test it today,
Thank you very much
regards
Hello Lupu and Tqnata, car starts , problem was in +12 volt ACC to WSP, thank you very much for your help ,your file is good,
regards
for this cars the best is to repair WSP dump otherwise very often start error comes back in some time, and then make ECU with autocoding like Tqnata and Lupu did, and start the car with old keys...
..you can do all that with Sprinter start error software...
hi boys I need ypur help again. Immo off on sprinter. ecu bin from st 5p08 attached. i need immo off. is it possible form engine ecu or I must read motorola in immobox too ? thanks
ecu engine 0281010615 BOSCH
VCDS 17.1.3, Xprog M 5.0
nobody ? please ? must read moto in immo unit ?
here is
sprinter repair.rar
kevino (7th December, 2015)
is it immo off ?
it is autosynhronisation. immo off not posiblle, only immo emulator.
kevino (27th December, 2015)
