Results 1 to 11 of 11
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Default 2007 GM - Saturn Ion 93c66
    2007 GM - Saturn Ion 93c66 with around 134,xxx miles
    I need it to 120,000 please
    And yes I know it can be done through obd, my usaprog cant do obd or eeprom.
    This is a 2007 Saturn Ion 2 93c66 eeprom file with 40,824 Miles can someone mod this file for 278,940 Miles please
    neospeedo's Avatar
    Garage
    Look for miles in the BCM 95040
    - Remember Don't Just Sit There In Boredom, Add to the Forum!!
  4. The Following 5 Users Say Thank You to neospeedo For This Useful Post:
    clusters (26th August, 2015), FxShaw (14th June, 2016), Johnner (21st August, 2015), XmoDDeR (26th August, 2015), zckariya70 (22nd August, 2015)
    I swapped the cluster and the mileage changed so it has to be in the cluster.
    neospeedo's Avatar
    Garage
    Your seeing the miles off the other cluster because the VIN in the replacement cluster isn't matching the VIN in your BCM. Once your VIN matches your BCM, your BCM will mirror the cluster. Hence, the miles are in the BCM.
  7. The Following User Says Thank You to neospeedo For This Useful Post:
    XmoDDeR (28th August, 2015)
  8. #6
    I will try this and report back.
  9. #7
    Thanks Neospeedo you were correct. It all worked well
    Thank you
  10. The Following User Says Thank You to testit34 For This Useful Post:
    neospeedo (26th August, 2015)
  11. #8
    clusters's Avatar
    Mar 2015
    Canada
    So did you have to modify the VIN in the cluster, or did it correct itself with a short drive?
  12. #9
    neospeedo's Avatar
    Garage
    I'm gonna go with he just changed the miles in the BCM.
  13. The Following 2 Users Say Thank You to neospeedo For This Useful Post:
    XmoDDeR (26th August, 2015), zckariya70 (27th August, 2015)
  14. #10
    Jan 2017
    NA
    I have a 2005 Ion with a replaced used cluster, the replacement cluster shows the car mileage that was pushed from the BCM, but its not counting any further. if the mileage updated would the vin be pushed as well? if not is the chip a 93c56 or 93c66? if so can i read the eprom with my carprog and just edit the VIN on the cluster to match the cars vin? or do i have to clone or transplant something off the old cluster?
  15. #11
    Feb 2018
    Houston Texas
    I'm working on an Ion with a replacement cluster. Is the vin stored in the 93c66? Should I write the original backup to the wrecker yard cluster?
