Results 1 to 8 of 8
    Top Poster + luisjimenez's Avatar
    Dec 2013
    Default Ford f150 2001 pinout cluster
    some friend who has the diagram to read the cluster ford f150 2001 hc11 I use the carprog programmer but I have no diagram thank you very much in advance
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    I have only for digiwigi or TU
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  3. The Following 4 Users Say Thank You to hcip For This Useful Post:
    Killer76 (28th November, 2019), luisjimenez (27th January, 2015), pongsky (9th March, 2015), viejomatius (27th January, 2015)
    Dec 2013
    in carprog be the same color and the same meaning
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    PIN 21 IS RCV AND PIN 20 IS XMT, PIN 1 AND 2 ARE GROUND. YOU MUST POWER UP THE MICRO TO READ. LOOKING AT BACK OF BOARD FIRST BLACK PLUG ON TOP OF CIRCUIT BOARD TO LEFT, FIRST PIN AT BOTTOM LEFT IS POWER # 11. 12 VOLTS +GROUND IS ON SECOND BLACK PLUG TO RIGHT, AT THE BOTTOM STARTING ONTHE FIRST PIN LEFT COUNT 6 OVER TO THE RIGHT YOU SHOULD BE ON PIN 17THAT IS YOUR GROUND.
    MIGHT HAVE TO CUT PIN 2 TO READMICRO 68HC11E9
    SOMETIMES JOINING PINS ONE AND 2 AFTER CUT
    USE A10 ADAPTER
    GREEN IS XMT
    YELLOW IS RX (RCV)
    VIOLET 12V
    BROWN GND
    OR POWER YOUR BOARD FROM A PSU
    SOMETIMES U NEED LIKE 6 WIRES BUT CAN BE DONE WITH FOUR
    GOOD LUCK..................
  6. The Following User Says Thank You to XmoDDeR For This Useful Post:
    luisjimenez (28th January, 2015)
    XmoDDeR's Avatar
    Mar 2011
    Quote Originally Posted by luisjimenez View Post
    THE BOARDS IN THE OTHER PDF ARE CORRECT FOR THE MODEL THAT CARRIES TAN AND GREEN BOARD BUT YOURS IS GREEN/GREEN CORRECT?
  8. The Following User Says Thank You to XmoDDeR For This Useful Post:
  9. #6
    XmoDDeR's Avatar
    Mar 2011
    CARPROG Motorola HC11 programmer manual.raror you can use this had to dig in archives
  10. The Following User Says Thank You to XmoDDeR For This Useful Post:
  11. #7
    DK Veteran buga37's Avatar
    USA
    This should help
  12. The Following 2 Users Say Thank You to buga37 For This Useful Post:
    bender (20th March, 2019), luisjimenez (28th January, 2015)
  13. #8
    Jan 2018
    The hc11 2003 Ford f150 you cut the jp157 and jump wire to jp115, after programming the cluster, do you remove that wire and resolder back the jp157 , or leave the jp157 open cut?
