Page 71 of 133 FirstFirst ... 2161666768697071727374757681121 ... LastLast
Results 1,051 to 1,065 of 1982
  1. #1051
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    would like to see if it does these H keys
  2. The Following User Says Thank You to whiskeyman For This Useful Post:
    cjawahir (19th January, 2016)
  3. #1052
    lidons's Avatar
    Feb 2011
    major flaw found in TM100.
    MODULE. 7936 hitag2 key ID46 with proximity to VW Passat.
    Chinese keys come with a CN3 within them, if you do it by the key module is recorded in the dumps and start OK.
    but to activate by OBD2 to operate the remote, continues to give it high for diagnosis to be a CN3. and left out of programming. Unable program for OBD.
    VW also works hitag unlock --- but only with transponder CN3 ok.
    with PCF7936 is not unlocked, leave message (Not Found).
    reviewing with FVDI, CN3 if the transponder is preloaded with 7bit. But it is not blocked and neither is blocked by OBD.
    CN3 is not valid for diagnosis.
    7936 Virgin putting a transponder on the key and encoding for dumps with TM100, this does NOT perform well preload 7byt CS, and yes blocked,
    with FVDI, you can not either, and preloading tagkeytool entering the key, and then try to register for OBD.
    excuse my English, is the best.
  4. #1053
    lidons's Avatar
    Feb 2011
    CN3 - add transponder by Dumps (tm 100) and it works ok.
    CN3 - can not give high by OBD --- (just dumps) - (this step is necessary to add remote later)because NOT (Locked)
    Remote - can not register, (for it is necessary to record the keys for OBD)
    Remote. This is not possible by dumps only for OBD. for this a PCF7936 is needed and NOT a CN3
    7936- not preload the CS with TM100,
    7936- is necessary to register for OBD. then the remote (keyless)
    Unlock TM100 VW Hitaig d46 comfort
    CN3 - ok
    7936 - Unable to not recognize.
  5. #1054
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    Quote Originally Posted by lidons View Post
    thanks - is this the ID46 CC passat ?
    - its rare but is out there
    I am a FUD
  6. #1055
    Nov 2014
    hello
    today i have kia bongo with eprom 95080 in ecu all key lost
    TM100 AND TANGOcannot recognize dump
    but EFFI can recognize but back file is full of 0000
    someone can check if dump is correct
    with any tool
    regards.
  7. #1056
    Oct 2015
    tango accept your dump. there are two keys id 46
  8. The Following User Says Thank You to rokibar For This Useful Post:
    philipcoin (29th January, 2016)
  9. #1057
    Nov 2014
    Quote Originally Posted by rokibar View Post
    i make key with tango.
    TM100 need to fix this bug.
  10. #1058
    Nov 2014
    anyone test this function
    How to edit ID46 IDE:
    1. Select TPReader, click "PCF7936";
    2. Input 4-byte IDE at P0, click button "Write";
  11. #1059
    Jan 2016
    When I try to connect and update tm100 I get Io error, I be sent it back to china ones it was brought back after two weeks went back to same IO error
  12. #1060
    Jan 2016
    Tm100 io error after update part 2 what could be responsible
  13. #1061
    I had this problem when I bought my Tm100 .
    I actually solved it through hotair soldering . but not sure about the part which I resoldered
    so , Firstly you need to connect with TM100 support team.
  14. #1062
    Jan 2016
    Pls how so I get connected to their support teem?
    I ve sent it back to China once for repairs
  15. #1063
    easy to log there site {FLY} and find what you need
  16. #1064
    Jan 2016
    Thnx a lot m-o-y I just did the hotair soldering and it worked,
    I think the EPROM was losing contact
  17. #1065
    Nov 2014
    TM100 cannot program hyundai immo in ecu eprom st95040.
    fly need to fix this bug.
