Results 1 to 15 of 15
    Apr 2014
    Default 2005 Transit connect dash swap and programming....
    I need to swap a 2005 transit connect dash with a used unit i have ids but i have never used it to swap dash/pcm etc any tips? also i have only got one key
    88diablo's Avatar
    Do you have any tools to read micro on old dash? If you have just read eep data from 912 and put in new cluster. If you dont you can buy UPA cheap.
    Apr 2014
    i have xprog and a batronics...? i thought its a non removable eeprom?
    88diablo's Avatar
    I thought the key data was in the micro eep data.
    Apr 2014
    I have no data on that dashboard is it a 8 leg eeprom chip?
    88diablo's Avatar
    No it should have a Motorolla MCU HC12 912, You should have BDM points, I dont have X Prog but Im sure it will read it. Just take dash apart, find 912 MCU and then look on your deevice how to read. I'll upload you the BDM points in ten when I;m home.
    88diablo's Avatar
    If you open dash and it looks like this then just wire with X Prog
  8. The Following 2 Users Say Thank You to 88diablo For This Useful Post:
    racin-snake (1st March, 2016), sjc1 (5th February, 2015)
    Aug 2011
    uk
    Quote Originally Posted by sjc1 View Post
    Just fit clocks mate and go to pats functions and program the clocks HEC (under initialization) you might need to get another transponder as if it fails you might have to erase keys and then you will need two keys to learn it again, not forgetting you will need incodes and if you unplug tool you will need to get another incode.
  10. The Following User Says Thank You to flyins For This Useful Post:
  11. #9
    88diablo's Avatar
    Quote Originally Posted by flyins View Post
    Exactly......... But if guy has X Prog or tool capable of reading MCU then surly soldering 4 wires seems simpler to me as imagine if mileage on new cluster is 100,000 more than on original then next post will be........ Please how to correct mileage in 2005 connect.
  12. #10
    Aug 2011
    uk
    Quote Originally Posted by 88diablo View Post
    Yes friend quite true as he might aswell do mileage while he at it!
  13. #11
    Try putting used clocks in first see if it starts not sure if immo is in clocks on early connect
  14. #12
    wiseman's Avatar
    Keys are not stored in dashboard in early transit connect.
  15. #13
    Aug 2011
    uk
    Quote Originally Posted by diagtech View Post
    Might be tddi, you could be correct, if tdci then clocks isnt it?
  16. #14
    Aug 2011
    uk
    Quote Originally Posted by wiseman View Post
    Quite true, didnt read his post properly, just assumed that he would of known and and just wanted tip of how to program, tdci in clocks? And tddi ecu and pump for pats?
  17. #15
    Feb 2015
    Germany
    which device I can, the controller at the Connect Reading and Flashing Ford Connect 1.8 TDDi year 2004?
