Results 1 to 15 of 15
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Default BMW E46 320d code 42
    Someone to disable this 42 error and limp mode on this BMW ?
    bmw zoki.rar
    Thanks in advance
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    What this code mean?
    Regards!
    carbon7319's Avatar
    Aug 2011
    Macedonia
    This is for - 42 DDE control module (EEPROM and configuration)
    I disabled this error but after that show me - 48 injection quantity regulation and BMW doesn't want to go after 3000 rpm.
    I think its mechanical problem on fuel injection pump.
    In measuring blocks BTDC its max 3 degrees.
    bobolin4o's Avatar
    Hm... try with this file, it's original one, but with different configuration.
    Nothing to lose...
    If no luck, try to update the ECU with WinKFP or Progman... maybe the problem is in EEPROM.
  5. The Following User Says Thank You to bobolin4o For This Useful Post:
    carbon7319 (11th February, 2015)
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Alredy tryed this and about 10 diffrend files in that ECU , same thing again and again.
    Thanks Bobo for your time to help me.
    bobolin4o's Avatar
    Scan the pump for DTCs (with k-line adapter on he's plug directly).
    Use this program...
  8. The Following User Says Thank You to bobolin4o For This Useful Post:
    Rotor (4th April, 2025)
  9. #7
    Top Poster + dom8's Avatar
    Nov 2012
    Baltic states
    autocom can fix it! its option reset if you have this error. try with it. i make 3 bmw with autocom! its calibrate pump injection map..something like that.
  10. #8
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    Mehanics vp44 is the problem i have fixed too many of them all same problem
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
  11. The Following User Says Thank You to kire106ka For This Useful Post:
    pandokrator (11th June, 2015)
  12. #9
    treo's Avatar
    R
    Quote Originally Posted by kire106ka View Post
    Can you tell us how?
  13. #10
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    I can thell you exactly byt not with words you have to see it it live you have to dissasemble fuel pump completly and you need parts sometime depends on situation with pump so without parts and new set for the pump is not possible to repair.Is not simple job.
  14. The Following 2 Users Say Thank You to kire106ka For This Useful Post:
    pandokrator (11th June, 2015), treo (30th March, 2015)
  15. #11
    treo's Avatar
    R
    Maybe you make a film and share with us your
    knowledge.
  16. #12
    nizarben's Avatar
    Dec 2013
    you have to change transistor pumpVP44
  17. #13
    treo's Avatar
    R
    Forget the transistor,kire talk about macanical camponents.
  18. #14
    May 2014
    Can someone tell me com port configuration please? Can?t get it to connect to pump. Using elm327 cable...
  19. #15
    bobolin4o's Avatar
    Quote Originally Posted by ddnc View Post
    Forget the f*****g ELM... you need a simple K-line adapter.
    Regards!
