Results 1 to 15 of 16
    In a van down by the river
    Default Replace CAS in BMW 1 Series
    Greetings All -
    I have a friend with 2013 year BMW 1 series and it needs new CAS module.
    He order by VIN from BMW, and it came with keys also.
    Can I program the CAS to this car with AVDI?
    Is it dangerous to try it?
    Any information is greatly appreciated.
    2013 should be f serie and there is no cas.
    It's do not think it is an F series, rather CAS3+
    The car uses PCF7945 key
    Unless of course there is F Series that uses PCF7945....?
    bearheroes's Avatar
    Dec 2011
    avdi won't program them because keys are not with factory isk...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    Let me give a little more info -
    My friend had an issue with the car and he replaced the CAS. Before he replaced the CAS, the car was completely dead.
    After he replaced it with a brand new CAS ordered by VIN from BMW, the car starts with the two new keys (and the old key) that came with the CAS. However, the car
    is in limp-home mode and there is an engine code that remains. I do not have the code.
    When I say replace the CAS, I mean he removed the old one and installed the new one - that's it. No programming at all.
    So I am thinking - the CAS needs to be properly married to the car. This is why I ask if the AVDI can do anything to help
    this situation. Any thoughts?
    DK Veteran 54321's Avatar
    When you buy a new cas from bmw it comes part coded to the car, you will need to fully code it using a suitable tool. The last one i did i used autologic to code it in. But i've been told original avdi can do it if you have licences BN010 and BN012
  7. The Following 2 Users Say Thank You to 54321 For This Useful Post:
    GameTheoryOptimal (8th July, 2016), indienick (11th February, 2015)
    bearheroes's Avatar
    Dec 2011
    it depends isn...maybe it needs synced, Avdi inpa etc can do this....It also may need to sync with ELV...AVDI also can do this.
    Dubai
    There is no Sync needed for such model, DME in this car is SK, not ISN.
    Just try to recode the CAS, no need to reflash.
    if same problems, check what's wrong in OTHER ecus, CAS should be OK
  10. The Following User Says Thank You to decno1 For This Useful Post:
    obdsystems (6th August, 2015)
  11. #9
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    what have you done with old CAS module indienick! Can i have it
    PS. tell CAS or F series by fob - different style i would think
    I am a FUD
  12. #10
    Quote Originally Posted by obdsystems View Post
    sorry my friend, we had to replace it, I think the old one was thrown away months ago :-(
  13. #11
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Why replace?CAS are easily repairable modules.
    Had 3 with the symptoms you mentioned - no ignition.
    Fixed within 30 minutes.
  14. #12
    May 2013
    Quote Originally Posted by simaservis1108 View Post
    Could you explain what needs to be done to repair the faulty CAS when No ignition?
    I have come across 2 or 3 like this before. Help would be much appreciated.
  15. #13
    Aug 2013
    Serbia,Belgrade
    Yes,you can add me on skype,and then we can talk.
  16. #14
    I don't have the tools.....
  17. #15
    Top Poster + mecanodiag's Avatar
    france
    hi can you clone me module FRM old on new one witch I buy from ebay ? car is bmw serie 1 F21 year 2013
