Results 1 to 7 of 7
    Default BMW E90 how to disable cornering light
    My friend has BMW E90 318i 2008
    With xenon cornering light
    One of headlight doesn't work because of moisture
    and message on display = Cornering light failure
    question is can i disable cornering light
    if yes what tool do i need
    example this tool: ???
    Obd k + dcan diagnostic cable ediabas inpa dis sss ncs ???
    auto leveling still work and all lights work just cornering light doesn't work and annoying mesage on display
    please help
    Feb 2015
    I did try to do that in a 09 X5 and it didnt work.You need to look for all options in FRM, footwell module.
    bram380's Avatar
    Indonesia +628153111774
    K+D-CAN cable and INPA NCS can disable this error.
    With NCS (fsw-psw profile) select NFRM module, read NFRM.
    Post here FSW-PSW.TRC file.
  4. The Following 2 Users Say Thank You to bram380 For This Useful Post:
    bearheroes (20th February, 2015), gokifly (3rd March, 2015)
    i will read and send file, and we see what will happen
    tnx
    Here is original FSW_PSW.TRC
    if anyone know how to sort this please help
  7. The Following User Says Thank You to gokifly For This Useful Post:
    DjRomeoR (21st August, 2018)
  8. #6
    I sorted this
    i changed this parameters in FSX_PSW file
    CHECK_SMC_ERROR
    ALC_FAHRZEUNG
    ALC_KLS_ENABLE
    all from active to nicht_active
    and now no error on display
    cheers
  9. The Following 9 Users Say Thank You to gokifly For This Useful Post:
    bonux (1st August, 2017), cscsaba (29th October, 2019), DjRomeoR (21st August, 2018), e15 (12th June, 2015), jjrp255630 (25th July, 2019), MBGL (29th August, 2019), plamen2 (5th October, 2020), r_parev (29th September, 2019), youngcat (8th September, 2021)
  10. #7
    bram380's Avatar
    Good info.
