Results 1 to 5 of 5
    Bratislava,Slovakia
    Angry VW Golf MK5 01299 code
    Hi friends!
    I'm going crazy with a golf. In the auto trans i get this error: 01299 - implausible signal.
    Donor car came, switched gateway, trans ecu, steering ecu, checked cables, but its still there. Coding is ok, flashed new softwares where i can. But i can not find the fault. Please help me!
    Thank you!!!
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    VAG Error Code: 01299
    Fault Location:
    Diagnostic Interface for Data Bus (J533) - No Signal/Communication/No or Incorrect Basic Setting/Adaptation - Intermittent
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Wiring/Connector(s).
    Defective Control Module.
    Possible Solutions:
    Check/Replace all faulty Wiring/Connector(s).
    Read Measuring Value Blocks (MVB).
    Special Notes:
    If the fault is only found in one control module, then most likely that module is the issue. However, if the fault is found several different control modules, then the CAN Gateway could be the issue.
    As taken from my EOBD II Fault Codes software which you can Google.
    Keith
    2010 Golf GTD (170)
    Bllinda's Avatar
    Baltic
    Try to rewrite softies 533. vaspc19 or vas5163(VASEGD2). If you need it stops updating the device is defective.
    need to prepare for this job. Bet or used J533
    Quote Originally Posted by Pzolee View Post
    Hi friends!
    Thank you!!!
    today
    A topic that interests me
    check vehicle speed sensor they tend to go very ( notchy ) test live data with vag-com with steady speed increase
    should be a nice even increment, if faulty eg: 7 - 19 - 21 - 29 -ect . rarely flag up a code directly and create all sorts of silly problems
    Jan 2014
    I changed the variant coding in steering column ecu then the p01299 code vanished in the tcm module but it starts giving other errors I'm thinking either the tcm is faulty or variant coding is off which I did not discover yet
