Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
    speedy100's Avatar
    Athens
    Default DDT2000 diagnostics
    I hope that someone will have experience with DDT2000 Renault Diagnostics and might be able to help me out.
    I have installed version 2.9.0.4. It runs OK it sees my VAG K+Can cable but it does not connect to the cars. I have tried with one Clio 1.2 16V 2001 model and one Kangoo similar model. It does not come up with any error either. Any ideas please?
    Thank You for Your time!
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
    VAG K+Can cable cant be used with DDT2000
    use vag 409 cable
  3. The Following User Says Thank You to ammarben For This Useful Post:
    speedy100 (21st March, 2015)
    Feb 2013
    HI!
    drivers are compatible?
    you can do tutorial?
    sorry for my English
    thx
    speedy100's Avatar
    Athens
    @ ammarben and flixuno : Thank You for Your reply guys!
    I do not have vag 409. I will try VAG KKL and see...
    Tutorial I do not know how to do.
    Best Regards
  6. The Following User Says Thank You to speedy100 For This Useful Post:
    Col19 (27th October, 2019)
    Feb 2013
    hi!
    I'll try to make tutorial
  8. The Following User Says Thank You to flixuno For This Useful Post:
    speedy100 (15th March, 2015)
  9. #6
    speedy100's Avatar
    Athens
    Quote Originally Posted by flixuno View Post
    hi!
    This would be a great idea as i have seen many people having all kinds of questions on this software.
  10. #7
    Hello friends, I will ask again your help . I have a ddt2000 working program with a mdb database and when i try to read e Logan ecu from 2006 i have this error: ecu refused to unlocked . Please explaine me why .
    Thanks!
  11. #8
    Quote Originally Posted by ammarben View Post
    use vag 409 cable
    Yes it can!!!
    These guys managed it too.
    http://ddt2000.pl/instalacja-program...sp3-pl-32-bit/
  12. The Following User Says Thank You to JustMeAgain For This Useful Post:
    speedy100 (25th March, 2015)
  13. #9
    speedy100's Avatar
    Athens
    Quote Originally Posted by JustMeAgain View Post
    Yes it can!!!
    Thanks but it is in Polish language and can not understand a thing.
    B.R.
  14. #10
    Quote Originally Posted by speedy100 View Post
    B.R.
    Google translate. Marvelous tool and its free.
  15. The Following User Says Thank You to JustMeAgain For This Useful Post:
  16. #11
    speedy100's Avatar
    Athens
    Yes I know. I have it installed but can not connect to any car i have tried so far. I used VAG K+Can and VAG KKL but no luck. I can not understan what i am doing wrong. Problem is that there is no user manual for it so no help... i will not give up though.
    B.R.
  17. #12
    Driver issues. Does ddt see the com port you're using? Are you using admin privileges? Are you running in compatibillity mode?
    I see you are using 2.9.0.4. Windows7 or 8 by any chance?
  18. The Following User Says Thank You to JustMeAgain For This Useful Post:
    speedy100 (26th March, 2015)
  19. #13
    speedy100's Avatar
    Athens
    Yes it sees the com port with both cables. I am using Win XP as admin and no compatibility mode. I run it through Internet Explorer.
    Thank You very much for Your time.
    B.R.
  20. #14
    Taking a guess then you need to alter driver .ini file to give a 10400 baudrate then once done that if not working try 2ms latency tme.
  21. The Following User Says Thank You to JustMeAgain For This Useful Post:
  22. #15
    speedy100's Avatar
    Athens
    Taking a guess then you need to alter driver .ini file to give a 10400 bitrate then once done that if not working try 2ms latency tme.
    Thank You very much!!!
    I will try Your suggestions and report back. It might be a day or two as i need to find me a Renault car to test on...
    Best Regards
