Results 1 to 15 of 27
    korrni's Avatar
    UE
    Smile Vw Touareg 3.0TDI BKS 7L0907401D 004120 - Intake Manifold Runner (Bank 2) REMOVE
    Hi there, could you help me remove the error code from the engine control unit? It's a VW Touareg 2005, it has DPF off and it has ABT stage 1, if anyone's interested! I'll post the full BDM ,read with BDM100, the error code is the following:
    P1018 - 001 - Lower limit not reached - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 133617 km
    Time Indication: 0
    Date: 2015.03.21
    Time: 14:42:18
    ORI.rar
    No password for the dump!
    Many thanks!!!
  2. The Following User Says Thank You to korrni For This Useful Post:
    Juragagan1 (16th July, 2018)
  3. #2
    Feb 2015
    Suraj
    Flaps Off disconnect connector
    Egr off
  4. The Following User Says Thank You to Prime For This Useful Post:
    korrni (27th March, 2015)
  5. #3
    korrni's Avatar
    UE
    Password for the archive? Thanks, mate!
  6. #4
    korrni's Avatar
    UE
    I'll try it right away!
    korrni's Avatar
    UE
    It does not work, it communicates, but no measuring blocks, cannot read the error codes, coding, car does not start!
  8. #6
    Feb 2015
    Suraj
    you write via BDM?
    Recalculates the checksum of the device itself
    password is the same
  9. #7
    korrni's Avatar
    UE
    Yes, with BDM 100, did the checksum after writing! Thanks for your interest, mate!
    The upper picture shows the initial state of the ECU, it communicates, I can read measuring blocks, coding, etc.
  10. #8
    Feb 2015
    Suraj
    starts on the original?
    check var 2?
  11. #9
    korrni's Avatar
    UE
    15 minutes, I'll post the results right away!
  12. #10
    korrni's Avatar
    UE
    Still the same result!
    It communicates, but no measuring blocks, etc..
  13. #11
    Feb 2015
    Suraj
    This on original DUMP?
  14. #12
    korrni's Avatar
    UE
    Nope, this happens when I write the dump you sent me. Same story for V1 and V2. I am not capable to read measuring values, etc, as shown in picture. With my original dump, the car starts without any problems! Thank you for your time, mate, really appreciate it!
  15. #13
    Feb 2015
    Suraj
    Check this
    2 file
    1. flaps off disconnect connector
    2. flaps off no disconnect connector
  16. #14
    korrni's Avatar
    UE
    Ok, I'll try and post results!
  17. #15
    korrni's Avatar
    UE
    Sorry to bother you, but no luck! The car does not start. Could you just remove that error from the DTC list?
