I got Megane 2009 lost card and locked. I don't have 'Laguna 3' Lishi, I have only for older Renault, but I think it will open the lock but not decode. Am I right or wrong? Fast answers very appreciated!![]()
Is it megan or laguna? you cant use laguna 2 in 1 ,in megan lock!, if its megan, the key way from 2003-2010 are same, i have used 2in in 1 in megan 2007 to open the car, but didnt decode since the owner had the code inside the car. It took me ages to open the door,till i increased alot of tension, and it opened in no time.
btw - this car was dead locked!
Will this photo help?
Megane 2009, black card 4 buttom. I just came back from car without success in opening it, as the lock turns but the door won't open. Seems like a clutch working on. The lock turns 180 degree. I will get key code.
I'm sure I saw here on DK that somebody wrote that it's possible to open laguna3/megane3 with lishi for old card system and that's why I didn't buy new lishi tool specially for Laguna 3 but after today I can't say it's true.
I am a FUD
They are 100% identical.
p1et (9th April, 2015)
I have key code like: 723832. How to covert that for a cuts?
This is The cuts, Just open instacode and You will see
p1et (10th April, 2015)
Ah, so this is that series 1234567HQ? I see when I put in viper '723832' it found that series. Also I managed to run 2010 instacode and I see the same. Thanks. Will report later if it worked.
One more question: Do I have to reverse those cuts when putting into machine or it will work straight? I'm asking cause I have 50km to the car and want to be sure today I will do the job.
Dealer code often has 8 digits. Take the first 6 digits and reverse to get the bitting. e.g. Dealer code 34213463 = bitting 431243
I got straight cuts from dealer, no need to reverse. BUT! The lock was spinning 360 degrees with a key O_o. I opened the car using wire and coded new card...
Lock spinning 360 degrees is the protection mechanism,when wrong key is inserted.
HeXeN (28th April, 2015)
I had 2 keys. One cut as the dealer code and 1 as reverse of that code. The wrong key doesn't turn at all.
is not the same...i have lishi for megane 2, and had to do a fluence 2012 all keys lost. It Works well to open the car, but decoding is wrong
