Hello guys,
What tool can accomplish this task?
I highly doubt it is manual procedure.
Regards,
Sima
Hello guys,
Regards,
Sima
Gscan avdi etc
simaservis1108 (13th April, 2015)
I just watched this,and decided to give this a try.
https://www.youtube.com/watch?v=wwWkVy7eiLI
I am awaiting for my AVDI to come,ordered it,but they are out of office until 24th.
Will report if it works.
X100 also will do the job
sima my friend -
unless AVDI have magical update / or this is 7941 etc -
i recommend AVDI with main-dealer GDS passthro - You dont get much except for diagnostics AND remote programming.
But assuming cos dealer u wont get stuck (he said)
Or other toolas suggested
I am a FUD
with sbb u can program remote kia ceed
To update you guys.
I could program IMMO with SBB,but not the remote.
It couldn't connect as Kia Cee'd.
Tried as Kia Sportage,it entered the procedure,but the seller gave me the wrong remote.
The right remote for this car is Omron OKA-185T CE0682.
I was given the remote Shenchang SEKS-AM08FTx.
Just wanted to give you guys an input about my case.
fadhle (16th April, 2015), iamfooser (15th April, 2015), ucokseparoh (15th October, 2016)
Hello
I lost my remote key fob for my UK KIA Pro Ceed 2008 do you think this key would be the correct one for me too?
I read on Internet I could maually re-program the key fob my self via:
Insert key and turn to on
Wind down driver window
Remove key
Open bonnet
Open diagnostic panel (not sure where it is on a Ceed)
Short pin 4 "counting from left" (rear row) with pin 8 "counting from left" (middle row) with insulated wire
Press Lock button twice
When chime operates the programming is complete
Repeat previous 2 steps for other keyfobs
Remove key
Remove wire from diagnostic panel
hello
i do not think ur ca can be program with manual procedure . u need diagnostic device for program ur remote
psheraton (14th October, 2016)
hi
i programming this car remonte control in MVP no token
i try SBB AVDI but no work
good luck
I may buy an mvp however has any tried this one? http://www.obdchina.com/sbb-key-prog...m_medium=v0014
it is sbb no mvp
i try sbb but no luck
https://www.aliexpress.com/item/Hot-...b-35fcef9c57a5
this work 100%
good luck
