Hy all DK members,
I got myself a bit of a situation. Car is 2009 EDC 16C33 2.0 DTI - Same engine as Opel Vivaro .
Problem for me is IMA codes- Only fault is injector codes not learnd.
I try : Tech 2 - Vauxhall Vivaro - all injector codes put in no luck - Injector code programming failed.
Autocom - Injector codes failed to learn
Launch Diagun X431 - failed
FVDI - Renault Trafic - IMA codes - FAILED
i reset all ECU parameters, everything.... still no luck
I dont know what's next.. .. Car was in a garage, all was fine until somebody erase all injector codes but i dont really know what tool he used to erase them.
Anyway ...wich is the best solution to fix this ? or any advice would be much appreciate.
Thank you in advantage. John
