Results 1 to 15 of 22
    garagetech's Avatar
    Oct 2008
    Default Bmw e60 service reset not possible
    Hi has anybody got the solution for this problem, bmw e60 couldn't do a brake-pad reset after changing them. Tried both ways manually and with obd but still at 0% . Along with this when i goto idrive service reset settings all serviceable parts are listed but couldn't reset from there either . Any clues how to fix this problem?
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    I had the same problem some time ago.I tried with autocom and other tools but only easy dis was able to do reset this servise.
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  3. The Following User Says Thank You to drewdom For This Useful Post:
    garagetech (22nd April, 2015)
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by drewdom View Post
    I have the isid ista will give this a try or maybe flashing could solve issue
    PierreTheron's Avatar
    Centurion,South Africa
    Had this before .
    Cleared all faults on all modules in the vehicle and then got it to reset ...
    garagetech's Avatar
    Oct 2008
    Reprogrammed module but no luck i assume cluster faulty or someone messed up whilst doing correction
    Aug 2011
    I'm sure you allready look at it look but onse I have same problem nad the problem was that non OEM sensor (was from TRW) had too short pin. IF it is unpluged and you try to reset it goes to -25000? Regards
  8. The Following User Says Thank You to pipina For This Useful Post:
    garagetech (30th April, 2015)
  9. #7
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by pipina View Post
    Cant even do engine oil reset they all greyed out in the idrive
  10. #8
    Aug 2011
    Quote Originally Posted by garagetech View Post
    Make CAS update ... I have same problem time ago when make corection and I corupted flash in CAS. All work ok except service interval was totaly mesed up and reset was impossible. Are other km and data for service corect? Regards
  11. The Following User Says Thank You to pipina For This Useful Post:
  12. #9
    garagetech's Avatar
    Oct 2008
    I did a full update including cas for some reason ista updated and flashed all modules but failed to code cluster, lm and body module. I tried 2 times same results.
    Odometer keeps dropping back aswell few hundred miles every time according to the customer and other resets are not available like distance calc just dashes!!!
    What do you think it could be pal ?
  13. #10
    Reprogramming will not help. You have to do a test plan or test schedule and then it'll will reset.
  14. The Following User Says Thank You to Speedosoft For This Useful Post:
  15. #11
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by Speedosoft View Post
    Done that also it didnt help
  16. #12
    pepi's Avatar
    Do you have DOT near km value?
    I had problems with services reset after correcting mileage , everythink was ok exept sevises.
    I check the actual values at CAS and there was stil 0 km. I plug AVDI by OBD and set 100km value at CAS and every think came back to normal the sevices were display just fine . so, synchronization between CAS and dash was faulty.
    I hope you solve your problem by our experiances.
  17. The Following User Says Thank You to pepi For This Useful Post:
  18. #13
    Garagetech did you just change the brake pads and the brake sensors or did you also work on the cluster? Because if you did you have yourself a corrupted file. If you did not, the only way left provided the sensors are brand new too is to drive the car a 100 miles or so and retry it.
  19. The Following User Says Thank You to Speedosoft For This Useful Post:
  20. #14
    garagetech's Avatar
    Oct 2008
    No customer saying he got car like this but brakes and sensors been change , if its the matter of correcting mileage dose anyone know what needs aligning cas cluster ecu or only ecu and cas?
  21. #15
    pepi's Avatar
    I just told you ,
    -check if there is a dot on dash
    - check the km value on CAS if it is the same with dash
    - correct km by OBD on cas with AVDI , DP3 or any tool who works with it.
  22. The Following User Says Thank You to pepi For This Useful Post:
