I got serial K6xxxxx35 will be mine locked if i update it ?
It will only f*#k the nxp if you update it wrong
This is the way every update work!
Updates done by ksuite are locked automatically.
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
antonypaul (15th June, 2015), gazvts (15th June, 2015), Maartinj (16th June, 2015), wen20v (30th January, 2018)
so if i did not copy the update folder over - I would have had a working Kess?
..This is exactly why somebody needs to make a tutorial - there are far to many opinions and misconceptions floating around. :/
this why there are people that can do the update for you!
Some say it is only about the money.....but the updates arn't expansive and are safe...
but if you try at your ow, every time a risk to make a mistake and block your tool!
I have this error. Can anyone help me?
vicius_the_one (18th June, 2015)
Update is only possible if FW is lower as FW 4.036
BTW:
OBD2buy.com has stolen ECU-Tuners Token reset Solution, with 99 Token Files.
Is this 99 Token or 99 x 30 Tokens?
http://www.obd2buy.com/file/KESS_V2_...R_SOFTWARE.rar
(The files are in ksuit temp folder)
There are also some protocol updates?! Did anyone know if this will work?
edit:
Every of this 99 tok files have the same MD5, this mean that every token file have the same content... --> only one Reset is possible??
hcsaibot (16th June, 2015), vicius_the_one (18th June, 2015), wen20v (30th January, 2018)
Work this one reset?
And what should the protocoll update aim?
It's all fake mate, like all the time!
hehe yes mate check this log file from sd card
Code:Info file for log: ver 1.000 Time: 23/02/2014 03:58.43 VoltStart: 13.61 Device SN: 66666666 GOS ver: 3.099 ManagerCode: D6666 ClientCode: D6666 Procedure: ECU Identification Brand: Model: Type: Protocol: FLASH_0310 BOSCH TRICORE MEDC17 BOOTLOADER ver: 3.004 Filename: FileOpt: FileMd5: Result: ERROR ErrorCode: 3B0B ErrorDescr: MICRO Wakeup error VoltEnd: 13.61Code:Info file for log: ver 1.000 Time: 29/11/2012 13:22.52 VoltStart: 11.87 Device SN: 12041102 GOS ver: 3.099 ManagerCode: C3553 ClientCode: C3553 Procedure: ECU Identification Brand: Model: Type: Protocol: FLASH_0313 BOSCH TRICORE MEDC17 BOOTLOADER TPROT8/10 - VAG ver: 1.029 Filename: FileOpt: FileMd5: Result: ERROR ErrorCode: 3000 ErrorDescr: Wake up error VoltEnd: 11.87
Yes it is the original details of the tool China cloned
