ford some time have problems whit J1850-PWM protocol(whit Bluetooth adapters), if is not working ,You must to change the adapter.
to work without problems whit protocol lISO-9141, ISO 14230 (KWP2000) ISO 9141 on BMW, OPEL, WV, AUDI, SKODA, VOLVOVAG you need COM 409.1
Mazda ecu is similar if you are Lucky by work .
must clean lvl Mazdaspeed whit LukyPatcher (ROOT requered)
Racing Meter inside .rar
[HIDE] ? Digital Gauges for RPM, Speed, Engine coolant temperature, Intake Air temperature, Catalysts temperature, Engine Load, Turbo boost, Fuel Consumption, Clock, Fuel pump and Rail pressures (gauge and relative pressure).
? ****og Gauges with Auto Scale, Warning and fully Customizable style, scale, angle, size and warning thresholds. For RPM, Engine Load, Turbo boost, Engine coolant temperature, Intake Air temperature, Speed, Catalyst temperatures, Fuel pump and Rail pressures.
? RPM LEDs Bar
Customizable colors, four styles and three animations available. Automatic or manual threshold settings. Two additional LEDs Bar are available to display Turbo, RPM or Load data.
? Gear Estimate
This value is calculated with the speed and RPM values.
? Customisable dashboard & profiles
Layout your own dashboard. Move, rescale, add or remove any parameters, three different layout profile can be saved and number of screens can be increased up to five. Frame and LEDs style fully customizable.
? Shift Light
Flash on screen, Automatic or manual threshold and color settings.
? Telemetry Viewer
Display Telemetry in real-time and save up to one hour of data. Two cursors can be placed on the graph to measure the time between two points.
The following data are recorded:
Speed, RPM, Gear, Engine load, Turbo boost, Lateral forces, Longitudinal forces.
? Import/Export the telemetry data as a CSV file on your sdcard for further calculations. Export to RaceRender format supported with the following data: Time, GPS Latitude, GPS Longitude, Speed, G-Forces, RPM, Throttle position, Gear, Turbo.
? Heads up display / HUD mode for night time driving.
? G-Force Meter (plotted 5s)
? Acceleration measures
Current and Best acceleration Widgets based on speed or distance. You can define the thresholds.
Units available:
Mph/Kmh ; ?C/?F ; psi/kPa/bar ; LPK/KPL/MPG [/HIDE]
