Results 1 to 14 of 14
    pepi's Avatar
    Default BMW E53 (X5) 2003 Battery Safety Terminal bypass
    I am trying to bypass resistance of BTS on E53 without success with resistance 2.2 ohm .
    There is still error
    MRS : Battery ,positive terminal isolation 1
    Does any of you did it and what resistace value did you use for it .
    Thanks in advance.
    Canada
    2.2 ohms ressitance
    If i helped you please press thanx
    Meat-Head's Avatar
    Cool read in a dirty magazine something daft like a 2 amp glass fuse is perfect
    pepi's Avatar
    I already try with 2.2 ohm it didnt worked , I will try tomorrow with 3.3 ohm or even with 2A glass fuse.
    Meat-Head's Avatar
    Press the smegging thanks button. Loook at the readings
    http://m.littelfuse.com/products/fuses/axial-radial-thru-hole-fuses/tr5-fuses.aspx
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    pepi (30th April, 2015)
    pepi's Avatar
    Not worked again
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Try 1 ohm..you know, if u have a good scanner you can just read the value the car is detecting. if 1 ohm dont work then use 2.2 and cut the freaking plug right off..and if that don't work then light car on fire and push it off a bridge..problem solve!
  9. The Following User Says Thank You to FxShaw For This Useful Post:
    Meat-Head (30th April, 2015)
  10. #8
    pepi's Avatar
    Tomorrow I will get same E53 and measure exact value .
  11. #9
    Meat-Head's Avatar
    Just skank it and stuff their bulb up
  12. #10
    ykizak's Avatar
    Nov 2011
    South Africa
    Quote Originally Posted by pepi View Post
    Thanks in advance.
    I usually use 2.7 ohm and it always works. However the fault that you pick up sounds like what i had with an old bmw.
    It kept giving me the same fault as you getting no matter what i did. I even tried to trace the wires up to module's plug and tried to put resistor there.
    It did not work either. So i believe with a slight chance there might be something wrong with the module itself. Maybe that fault is recorded on it somehow.
  13. #11
    dunnnia's Avatar
    LT
    Hi.if you have pasoft 1.4 simply disable it.
  14. #12
    Thanks in advance.
    Use 2.2 but cut the wires.
    Cheers
  15. #13
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    yes you need to cut wires.i use allways 2.2
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  16. #14
    smokey08's Avatar
    Essex, UK
    Best way would be to use ncsexpert to code it out of the airbag module. SBK is what it will be called
