Results 1 to 15 of 29
    Default Vauxhall insignia cd600 navi
    Is it possible to use a second hand radio in this vehicle. The original is faulty.i have acquired a cd600with no security code. Is it possible to virginise so it can be used. If so what programmer. Or is the radio married to display like older versions cd30, thanks
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    No. Is VIN based with BCM. Change VIN inside radio or use AVDI to reset via OBD2.
  3. The Following User Says Thank You to lupu_sandu For This Useful Post:
    radiosolutions (17th May, 2015)
    zalupentiy's Avatar
    Nov 2014
    Canada
    Read flash from unit.
    I have single dump...
    I didn't fart,my ass like you so much it just blew you a kiss.
  5. The Following 4 Users Say Thank You to zalupentiy For This Useful Post:
    carradio2001 (31st March, 2020), ilen (17th May, 2015), radiosolutions (17th May, 2015), REZON (17th May, 2015)
  6. #4
    What chip do I have to read .radio is, entry navigation eur/Kor. 7 612 034 237. Gm0300c0664120. 95137306.
    Stoyko's Avatar
    Bulgaria
    Quote Originally Posted by radiosolutions View Post
    What chip do I have to read................
    What chip's for reading have inside ? Read All.
  8. #6
    Is it a eeprom or processor
  9. #7
    Can not find which ic I have to read to change vin, has anyone done this radio before,who could help, thanks
  10. #8
    evanselec's Avatar
    Shropshire
    Default vauxhall cd600 navi
    can you tell me which ic it is to read and can it be done in circuit and if so what should be used connection wise
    many thanks Les
    Quote Originally Posted by zalupentiy View Post
  11. #9
    Anyone have a solution for this radio
  12. #10
    evanselec's Avatar
    Shropshire
    Default help please anyone
    it does not look like anyone has an answer for these units I have asked in many places but no reply's
    Les
  13. #11
    Jan 2017
    Yes you need to buy the VCI codes from GME infotech
    I have done this and it works fine
    Gav
  14. #12
    alclot's Avatar
    Melee Island
    Hi. I have opel mokka with this navigator. Any idea how to get pin onm bench or from dump?
    I´ve never did this unit.
    Thanks a lot
  15. #13
    Mar 2013
    Warsaw
    No pin in this unit.
    Security on vin only.
    Wysłane z mojego LYA-L29 przy użyciu Tapatalka
  16. #14
    carradio2001's Avatar
    France
    Maybe VIN in BGA Flash S29GL064N90FF.
    Carradio2001.
  17. #15
    Mar 2013
    Warsaw
    Radio can be unlocked via OBD using MDI
